Front bumper removal, stuck
Old Apr 21, 2018 | 08:56 AM
Maraud's Avatar
Default Front bumper removal, stuck
Hi,
I have tried to remove the front bumper today, without succes
Couldnt find something about it in the workshop manual, so I checked the forum for a how-to.
I removed the bumper from a x305 before.
Just as the how-to describes and worked for me on the x305, I tried today on a x300 without succes.
I removed the shield underneath, removed the end of the air ducts so they are hanging free on the bumper, I unbolted the 2x 19mm bolts up front.
There is some play, but its stuck somewhere still.
I do not want to break anything.
What am I missing?
Old Apr 21, 2018 | 09:15 AM
Lady Penelope's Avatar
Might be something in here :
https://www.jaguarforums.com/forum/x...removal-43954/
Big bolt locators mentioned in this one :
https://www.xj40.com/viewtopic.php?t=7888
https://www.jaguarforums.com/forum/x...-97-xj6-53175/
https://www.jaguarforums.com/forum/x...emoval-111990/
Old Apr 21, 2018 | 09:23 AM
Maraud's Avatar
yeah , it must be stuck on the bolt locators.
Any tips on how to approach this?
Would a spray of some lube oil be sufficient? Or do i need to lift it up maybe and then slide out.
Old Apr 21, 2018 | 10:06 AM
I haven't done it myself but may be referring to a through bushing . Dissimilar metal corrosion problem . There was a good post and pics on the rear as I think they are the same . Below is a pic of the non shock absorbing hardware setup and the absorbing setup is different . Links :
http://jaguarvp.blogspot.com/2013/04...t-corrode.html
http://jimbutterworth.co.uk/8bumper.htm
Old Apr 21, 2018 | 10:09 AM
Maraud's Avatar
The bolts came out without any problems, no corrosion on them either.
Old Apr 21, 2018 | 10:24 AM
New links in above edited post
Old Apr 21, 2018 | 10:29 AM
Maraud's Avatar
Thank you for supplying some links, I had found the same.
I read this thread, they mention something about "liners" in the last post.
I am not sure about what liners are they talking about.
https://forums.jag-lovers.com/t/x300...-x308/238259/9
Old Apr 21, 2018 | 11:28 AM
Liners might be referring to through bushings or spacers as item # 2
https://www.jaguarclassicparts.com/u...bsorbing-strut
Old Apr 21, 2018 | 11:36 AM
Or it could be slip in guides to hold the bumper shell in place on the sides . Looking now .
Yes it does on the very back on both sides , may be stuck
Old Apr 21, 2018 | 02:29 PM
Maraud's Avatar
Yeah, ill have a fresh look tomorrow with day light.
Spray lube on the "liners"
Though it seemed today it was still stuck somewhere in the middle.
I appreciate your help alot Lady P.
Old Apr 22, 2018 | 01:45 PM
Maraud's Avatar
Mission succes!
It was stuck on the bolt locators, with some lube and patience it came finally off.
Old Apr 22, 2018 | 02:06 PM
What where the locators ? In the parts diagram or where they the side slide in things ?
Old Apr 22, 2018 | 02:17 PM
Maraud's Avatar
The two mounts up front. There is this spacer that needs to come out before you can push it off the mounts. Both of them were completely stuck in the mounts.
no.2 in the drawing.
I installed the power washers today.
Old Apr 22, 2018 | 03:15 PM
Thanks and I just put the right side X308 headlights in this weekend and what a difference from the X300 in the left .
Old Apr 22, 2018 | 04:03 PM
Maraud's Avatar
I cleaned my old set before installing the x308 headlights.
That makes a big difference too! The right set is cleaned.
Old Apr 23, 2018 | 02:17 AM
robbird10's Avatar
How easy was the re-wiring for the 308 lights? Did you follow the Jim Butterworth article?
Old Apr 23, 2018 | 02:23 AM
Maraud's Avatar
I was in luck and pulled the x308 headlights from a x300.
So the cables were already fixed for me ;-)
But it seems a simple job.
joycesjag
40
Apr 8, 2016 10:13 AM
97X300VP
Apr 21, 2011 10:26 AM
Oubadah
Oct 18, 2010 04:18 AM
supercharged-xkr
Aug 30, 2009 06:22 AM
JimC64
Mar 1, 2009 12:57 PM
