HandBrake to hub back plate connection
Old Jan 29, 2024 | 11:51 AM
rich201060's Avatar
Default HandBrake to hub back plate connection
Hi,
Im having some difficulty connecting the handbrake cable to the hub, theres a white plastic clip that connects a spigot from the brake back plate to the new cable, the groove in the clip is 3mm but the cable and spigot combined is 4mm ish . No way there both going to fit in the groove, I'm starting to think I have the wrong cable but ive checked and theres isn't another number for the X300 , anyone else had this issue?
Rich
Old Jan 29, 2024 | 04:32 PM
b1mcp's Avatar
Yes I have vague memories of having the same issue when rebuilding the rear brakes on my car after a catastrophic failure that mangled a lot of components. I had the same thought that I had been sold the wrong cables. I think also that if the cable and spigot go together then the overall length of the RH and LH cables was too short to reach the centre cable.
My conclusion was (and I don't know if it's right) that the spigot on the backplate and the cable don't go together. I built mine with the white clip just on the handbrake cable and stopping it pulling through the hub carrier - see picture. It worked well for years before I sold the car.
Hope this helps.
Old Jan 30, 2024 | 01:33 AM
rich201060's Avatar
Thanks Brendan,
Thats helpful I have the whole of the rear suspension out so I can check the cable length easily. In your image the spigot appears to be missing like mine. I have acquired a pretty rusty spigot of an old back plate and the lip is about 1mm , I've also seen images of the genuine Jag cable can't be sure but the end does look thinner, Im going to modify mine if the length is ok and i will need to make the spigots !! I will post my results on here.
Rich
Old Feb 1, 2024 | 10:46 AM
rich201060's Avatar
I have ended up making 2 bosses as mine are missing, i managed to acquire a really corroded one to get the height 30mm with an 18mm spigot 1mm thick , the rest I made to miss the hub and 2 6.5mm fixing holes 68mm centres .
I then discovered the cable end is too thick for the plastic clip and needed to be 2mm not 3mm , Im not sure if the original cable is correct but the one I have is an after market part. Anyhow took a mm off it in the lathe which allows the clip to fit, I am going to finish off the IRS now and will see if there are any issues with the length.
Old Feb 1, 2024 | 04:03 PM
b1mcp's Avatar
Nice work. Would be great to see a photo of the completed install. When I was doing mine I could not find any reference diagrams or photos.
Old Feb 1, 2024 | 04:10 PM
rich201060's Avatar
No problem Brendan I will post some images once I have it all together, just got to paint it all first.
Rich
Old Feb 3, 2024 | 11:39 AM
rich201060's Avatar
Just for anyone with the same issue , some more images of my hub assembled with the shoes and cable.
Old Feb 3, 2024 | 12:46 PM
b1mcp's Avatar
Good for another 30 years!
Franklw
21
Sep 20, 2023 01:40 AM
Brooklyn
Dec 29, 2018 09:48 PM
Johnken
Nov 8, 2017 07:40 PM
nealschiffbauer
Mar 14, 2014 09:49 AM
