Help - coolant level sensor dropped out!
Old Jul 3, 2018 | 03:40 AM
AL NZ's Avatar
Default Help - coolant level sensor dropped out!
Time for a dumb question - do I need to worry about my coolant sensor which has dropped out of the bottom of the expansion tank?
i have just changed my XJR Rubber hose from MAF to alloy casting, then went for a short run. The coolant light was on, so I looked and the sensor has dropped out - I must have bumped it when wrestling the new rubber hose into place. There is no leak - seemingly it doesn’t actually sit in the coolant?
Do do I need to worry?
thanks for any replies
Old Jul 3, 2018 | 03:53 AM
b1mcp's Avatar
No cause for concern. It won't leak.
It just sits in a recess in the tank. Put it back in and if necessary secure with some appropriate adhesive or sealant.
Old Jul 3, 2018 | 01:03 PM
Qvhk's Avatar
Just plug it back in and it will be fine, unless it is deformed or broken.
JCHouston
Jun 25, 2015 10:31 AM
JagYour
Jan 7, 2013 05:05 PM
pomosv
Nov 6, 2011 10:29 PM
cromero
Oct 14, 2011 06:53 PM
EZDriver
Oct 14, 2011 03:15 PM
