Help Needed – X300 1997 Central Lock / Keyfob / Trunk
Old Dec 4, 2025 | 01:58 PM
ArturasM's Avatar
Unhappy Help Needed – X300 1997 Central Lock / Keyfob / Trunk
Car: Jaguar XJ6 X300 Sovereign, 1997, European model 3.2
Symptoms:
  1. Central locking:
    • Keyfob blinks but does nothing.
    • Dash/console lock/unlock button does not work.
    • Trunk release button (interior) does not work.
  2. Lights:
    • Interior and exterior lights work normally.
    • Side indicators do not flash when pressing keyfob. No sound, nothing.
Observations:
  • Checked visually all relevant fuses in LH/RH heel boards and trunk; all appear intact also checked visually and reconnected BCM behind glove box and Security module in the trunk. Nothing
  • Car was parked next to several other vehicles overnight and locked successfully; in the morning (-3 Celsius), it wouldn’t unlock with the keyfob. Replaced Keyfob battery. Unable to dot he keyfob reset connection procedure cause valet button seems to not work.
Any ideas?
Old Dec 4, 2025 | 04:09 PM
Parker 7's Avatar
Main car battery charged as may have drained , this would be a resolvable parasitic battery drain you can resolve yourself
Trunk fuse 3 or 4 as the SLCM fuse
Large connector above the fuel tank ( have to remove fwd trunk panel ) has a tie wrap on it clamping connector tight < do not remove connector yet
The batteries in the Fob can be easily installed wrong polarity
Do not install main car battery in backwards , positive post car fwd
Do not over tighten the positive battery post bolt , breaks special nut underneith
There is a SLCM " Hard Reset " but yours is European so a precaution if you have the original Jaguar / Alpine stereo head
Check to see which frequency version of antenna you have on rear glass
Old Dec 4, 2025 | 04:43 PM
Parker 7's Avatar
Car sitting in rain overnight ?
This allows water to pool in the fuel cap well and if the drain line is clogged water will spill over the well on the SLCM 4 connectors driving it nuts or hung up in a logic step not zero state
To clean connectors the battery positive terminal must be removed for SLCM connectors removal and install , keep track of which connector goes were or one at a time still battery cable removed
Old Dec 18, 2025 | 05:21 PM
Jaguar2025's Avatar
Default same issue...
greetings, we have the same issue with out Jaguar x300 4.0L 1996.
the vehicle battery is brand new (very high quality AGM and professionally installed)
battery drained while we were away.
recharged the new batter and it has been tested and is fully charged.
card will not start: turn key, dash lights come on, lock unlock (dash) button is RED. car will not start. no sound when we turn the key.
key fob does not lock or unlock the vehicle anymore (new batteries installed and the batteries were also new before).
dash lights come on.
interior lights do not come on.
trunk light does not come on.
fuel cap will not open.
trunk open switch does not work (can open the trunk with the key only).
if you do fix your issue please let us know.
all fuses were checked twice.
thanks!
Old Dec 18, 2025 | 07:04 PM
Parker 7's Avatar
The starter circuit needs a starter enable from the SLCM , The SLCM can be " Hard Reset " to zero state as yours is a US model without the stereo locking out
Remove both battery cables from batt and join cables together in the air with maybe a heavy battery jumper cable , this is a very low current situation so no fear , place a towel or the neighbors dead cat on exposed battery terminals , the longer the cables together the better like overnight
You can try a short 10 minute cables together then if no joy overnight
This will not effect the engine ECU as in other cars
Never install battery in backwards , positive post fwd and mark with white tape
Never over tighten the positive post battery bolt , splits special nut underneath
This process also resets the BPM which gathers the starter enables like trans position
Old Dec 18, 2025 | 07:20 PM
Parker 7's Avatar
A professional can still install battery backwards , ask me how I know
Old Dec 18, 2025 | 07:30 PM
Jaguar2025's Avatar
thank you so much! great, i will try this tomorrow morning and let you guys know what happens.
Old Dec 19, 2025 | 01:17 PM
Jaguar2025's Avatar
Default See diagram...
ahoy, we tried this (see diagram in case we made an error). no change so far. thanks.
Old Dec 19, 2025 | 04:41 PM
Parker 7's Avatar
Correct on hard reset pic
The fuse for both BPM and SLCM is in the trunk
To get power to the BPM ( starter enables gather )( behind glove box ) it goes through the BT - 4 large connector above the fuel tank which needs a tie wrap on it to clamp tight
Do not remove connector yet , just remove trunk fwd panel and see
There are some terminal nuts to check and the first is the Mega Fuse box just fwd of the batt positive post and then some task on the engine rear firewall battery terminal posts , remove the engine side cars left and right cable ( to the left and right engine bay fuse box ) with the cable removed wiggle the terminal stud , this is power to the starter solenoid
relays in the corner of each fuse box 5 - 1 ? the left engine bay fuse box relay only controls the horn so swapping option
Old Dec 19, 2025 | 05:20 PM
Jaguar2025's Avatar
thank you, again! we will look at these components over the weekend and post updates here. cheers!
Old Dec 19, 2025 | 09:31 PM
Parker 7's Avatar
the 2 terminals to wiggle are on the engine rear firewall
one other is inside the engine bay on the right wheel well very near the rear firewall , this is the starter cable / alternator feed back direction to the battery and such
and if you look through the intake pipes you will see a junction terminal of the battery cables on the starter solenoid top post that someone made a great pic of . this is a tie point where the right wheel well cable ties to go up to alternator B +
pics coming
Old Dec 19, 2025 | 09:47 PM
Jaguar2025's Avatar
great pictures! thank you.
Old Dec 20, 2025 | 03:02 AM
Jaguar2025's Avatar
Default Jaguar x300 1995 not 1996
UPDATE: FYI this Jag is a 1995 not 1996 (just checked the title).
Old Dec 20, 2025 | 05:56 PM
Jaguar2025's Avatar
Default Missing Black Relay in Boot Fuse Box?
Jag x300 4.0L 1995:
Greetings, [see image]
Does anyone know what the Black Relay in the Boot is for? I am hoping that no one stole it -- thus causing my no-start issue. The relay diagram I found online does not have the same configuration as this. Not sure where to buy one, or what the specs are. Thanks.
Old Dec 20, 2025 | 06:06 PM
Parker 7's Avatar
See page 19 , trailer
jagrepair.com/images/AutoRepairPhotos/X300 1996 LWB.pdf
Old Dec 20, 2025 | 08:08 PM
Jaguar2025's Avatar
thank you so much! i made a blunder with the year--my jag is 1995.
i have been checking the components you mentioned and they all look brand new, clean, and dry. no corrosion at all. need to get someone to help me test the connections as well. and today i located the SLCM and unplugged it, tried to start the jag, no luck. and no change after reconnecting it.
did not break anything. that is a big plus for me. thanks for all of your support.
Old Dec 20, 2025 | 08:20 PM
Parker 7's Avatar
The SLCM has to be plugged in and powered to be able to provide an enable ( digital ) to starter rotation
To plug SLCM back in positive battery post must be removed or the sequence of the many wire pins making will make the SLCM nuts
Old Dec 20, 2025 | 08:40 PM
Jaguar2025's Avatar
great. thank you. maybe it was already nuts? there were no visible changes after it was plugged in again. still the same dash lights, still the same "no start". the suggestion to unplug it and plug it back in came from a vintage auto restorer here in our area (vintage tech expert). but he is not a jaguar mechanic, he does get all his vintage car electronics working perfectly though--very complex systems. he had done some research and gave me a list of things to try. anyway, if the car is crazier now than before--i have not (yet) noticed. time will tell. heh.
Old Dec 21, 2025 | 09:32 AM
Parker 7's Avatar
The SLCM comes in many part #s based on year ( different freqs 315 or 433 ) and depending on region of world
This is probably the best part # source
Do you have 1 front door lock barrel or 2 left and right ( the SLCM is different and connector wires different pins )
If the SLCM is nuts a hard reset to bring back to zero state
Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic / Security/locking Module | Jaguar Land Rover Classic Parts
Old Dec 22, 2025 | 02:13 PM
Jaguar2025's Avatar
Default valet switch
the SLCM seems okay to me *blink blink*. however, the valet switch appears to be disconnected and i cannot figure out where to connect it as there are two matching female connectors. hopefully i can find an image of someone who has theirs properly installed. if i can resolve that then perhaps i can reprogram the key fob and disarm the system.
yes, i have two locking barrels on the left (driver) and right (passenger) front doors.
the mystery continues. cheers!
