i cant seem to remove this bolt any * help*
Old Jan 8, 2014 | 04:37 PM
vandenplas408's Avatar
Default i cant seem to remove this bolt any * help*
i went to replace my tie rod ends , lower ball joint s, lower shock bushings
upper shock bushing and shocks
i want to start with the shock since they are CRAP aftermarket replacement..i mean i got BOTH for $45 BRAND NEW SENSEN
i will try to get my OEM ones rebuilt if i can for a decent price.
but my shocks are toast and so are the upper bushings
they can move if i grab the thread and wiggle pretty bad. kinda scary
any ways the top bolt is 17mm.
i have a cool bent 17mm wrench but i cant for the life of me get the thread to stay still while i turn. i try to hold with several items ..
nothing could hold it while i was turning i do not want to damage the threads and get screwed over.
do i need an impact tool? or electric power tool good enough
i do not have air tools or access to any... i can buy a ele power tool but how many FT lbs u think i would need to zap that bugger off there
Old Jan 8, 2014 | 05:54 PM
AllanG's Avatar
you need to hold the top of the shock bolt with a set of vice grips or wrench and then use a spanner on the nut. It's laborious but you'll get there eventually
Old Jan 8, 2014 | 06:12 PM
ill give it one more shot maybe some good electric tape around the vice grips will prevent thread damage. even tho on top of thread looks like there is a spot the vice can fit
Old Jan 8, 2014 | 06:23 PM
AllanG's Avatar
Yes the top should have a couple of flats you can get a wrench or grips on.
Old Jan 9, 2014 | 11:02 AM
mgb4tim's Avatar
This is a how I remove this type of shock...
I put a socket with a long extension on the top bolt. Then, I rock it back and forth to snap the top right off. If they are headed for the scrap bin, why bother unbolting them?
Old Jan 9, 2014 | 12:23 PM
AllanG's Avatar
Well yes you could, but often you just need to remove them to change the bushings. Also you still need to use something to hold the shock while you tighten the nut when you install/re-install the shocks.
Old Jan 10, 2014 | 08:34 AM
mgb4tim's Avatar
In lesser cars, by the time the bushes were worn, the shocks were shot. Normally, I used a small, 3/8" (I think) open-end wrench or vise-grips to hold the new bolt from spinning while I tightened the new shock in place.
Old Jan 10, 2014 | 04:49 PM
OK so I do not think these shocks work for the jag
Ill post pics with exactly what I'm talking about.
My front right shock. Moves when I giggle the bolt from the enigne bay... its always done that but I do not think TS safe.
The new shock I got is even worse. Maybe I'm installing wrong but I doubt it
Old Jan 10, 2014 | 07:50 PM
Attached Thumbnails i cant seem to remove this bolt any * help*-ha.jpg   i cant seem to remove this bolt any * help*-he.jpg   i cant seem to remove this bolt any * help*-hi.jpg   i cant seem to remove this bolt any * help*-ho.jpg   i cant seem to remove this bolt any * help*-hu.jpg
Old Jan 13, 2014 | 04:03 AM
Ziggy's Avatar
There should be 2 bushings and 2 of those dished washers on each shock - one of each above the bodywork and one of each below - it looks like you've not got all of the bits!
See the diagram here for what you should have: Road Spring and Damper-Front - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
chatmanx
Sep 11, 2015 07:17 PM
sadepol01
Sep 11, 2015 05:26 AM
