idling issue
Old Sep 25, 2012 | 04:02 PM
etaent's Avatar
Default idling issue
So a while back i posted that i had an issue with my idle control.. since then i have replaced the tps, iacv, and the throttle body. the problem persisted, everytime i slowed down the car would stall. so i disconnected the brand new iacv and presto, no more stalling. but i dont want to leave it disconnected as this is not the answer, also sometimes out of no where the idle will drop and the check engine light will come on and rapidly shut off and the idle go back to normal. any ideas?
Old Sep 25, 2012 | 04:44 PM
jeremiahjaguar's Avatar
When was the last time you checked the coils? , a scanner would be very helpful or have them checked at the shop. a cheap and inexpensive way is to wait until tonight remove the coil cover and start your car. should you see any arcing at any of the coils you will know that the coil needs replacing.
Old Sep 26, 2012 | 09:24 AM
etaent's Avatar
Hey Jeremiah thanks for your response, yes i have checked the coils in the past. they were all functioning 100%.I will check tonight to see if they are arcing but i dont think thats the problem.
Old Sep 26, 2012 | 11:30 AM
Roger95's Avatar
The intake boot can be very difficult to get a good seal on the throttle body (allowing unmeasured air) - check that. Also the oil cap in the cam cover can leak air; you may want to replace it.
Old Sep 26, 2012 | 11:57 AM
etaent's Avatar
I will check the boot, but what do you think about the car running well without the iacv connected? very odd dont you think roger?
Old Sep 29, 2012 | 09:27 PM
Roger95's Avatar
You're not throwing a code? It has to be an air leak... Check the mounting of the IACV to be sure it isn't loose.
Old Sep 30, 2012 | 12:29 PM
XJRengineer's Avatar
Is the car still running the original crank position sensor. It could be an intermittent failure of the sensor. When the ISCV is disconnected it may be left in a position that gives a higher than normal engine speed. This would make the engine more robust to an intermittent CPS failure.
Old Oct 1, 2012 | 09:13 AM
EZDriver's Avatar
What is the IACV?
Old Oct 1, 2012 | 12:25 PM
etaent's Avatar
IACV is idle air control valve. It is a small round black object located on the top of the throttle body. the iacv is mounted tight and brand new might i add. And i will change the cps, once you send me the new bracket XJR! And i will also check for air leaks. thanks guys.
99xk8guy
May 28, 2024 09:36 PM
Bcrary3
Feb 21, 2023 04:29 AM
Rivguy
Dec 4, 2020 07:55 AM
joesoap
Sep 10, 2015 01:09 AM
Bowman
Sep 3, 2015 03:17 PM
