Jacking point on rear subframe.
G'day Ed,
You might have trouble getting a trolley jack under the front of the car to the crossbeam as the car is so low. What I do is jack the car up on one side using the normal jacking point and place a large wooden block under one of the front wheels Then you should have enough clearance to get under the crossbeam.
Cheers,
Jeff.
Cheers,
Jeff.
