Jaguar XJ6 1996 Steering Column problems
Old Apr 30, 2008 | 07:10 AM
clubmia85's Avatar
Default Jaguar XJ6 1996 Steering Column problems
hello everyone, I just signed up to this, and I had a question. I have a 1996 XJ6, and I bought the car with a loose steering column. I bought another one used off of ebay hoping to be tight and it was loose as well. I took it to a local private shop that only works on jaguars and tey said that all of these type of jagaurs are like this, where they all have play in the wheel. I dont know if its true? Does anyone know? I am looking at one on ebay now, and the guy told me that he had no problems that his is tight. Can it be in the gearbox or something else? Please let me know, thank you!
Old Apr 30, 2008 | 10:42 AM
ken@britishparts.com's Avatar
Default RE: Jaguar XJ6 1996 Steering Column problems
What do you mean by loose?
Old Apr 30, 2008 | 12:42 PM
clubmia85's Avatar
when i shake my steering wheel up the column is loose. Also when I shae from sides to sides its a little loose, but not as loose as up. When I put the tilt all the way down its less loose almost tight all the way but not quite, but as soon as I raise the tilt its more loose again. I know it dosent affect the car performance its just annoying, please help, thanks.
Old Apr 30, 2008 | 08:48 PM
jag_genius's Avatar
yeah thats normal..
Old Apr 30, 2008 | 09:42 PM
clubmia85's Avatar
is this in every xj6 or in every jaguar that the column is loose? Why would it be like that its just annoying and when u hit a bump it viabrates it really does suck....
Old May 1, 2008 | 06:52 PM
jag_genius's Avatar
they move up/downwhen you tug on it.. but it shudnt move when driving..
Old May 4, 2008 | 05:22 PM
clubmia85's Avatar
it loose at all times, maybe its worn out? I e-mailed a guy on ebay thats selling one and said his is very tight, so maybe if I install it on my jag it will be tight too< or is it soemthign else in myc ar thats making it loose?
Old Feb 12, 2011 | 11:17 PM
bandre2's Avatar
I found a fix for the loose steering column. Move the steering column tilt all the way in the upward position untill the motor stops. Then remove the two torx screws under the column by the tilt motor shaft. Pull down after removing screws and push steering wheel up as far as it will go and push up on the loose piece so the gears can be set correctly and then tighting the torx screws. Complete
Old Jul 9, 2011 | 02:19 AM
RBA's Avatar
RBA
Awesome, thanks! I purchased a X300 today with this symptom. Glad to hear there's a fix for it.
Old Jul 10, 2011 | 10:23 AM
bandre2's Avatar
anytime. Let me know if i can help anymore. Hope you enjoy your xj
Old Jul 24, 2011 | 08:15 PM
jagman96's Avatar
bandre, can you be a little more specific about the loose steering column repair, i will try this on my car
Old Jul 25, 2011 | 04:40 AM
bandre2's Avatar
I will get some pictures of the pieces that need to be removed so you can adjust it. from what i see its a gear that jumps out of sync with the shaft that the tilt motor turns over time. The torx screws have lock tight on them and can be very difficult to remove.
Old Dec 31, 2011 | 05:41 PM
mrleemyles's Avatar
Worked perfect, thanks
rusty37
Jun 7, 2016 04:43 PM
jdzubas
Oct 4, 2015 09:14 AM
SkinnyLard
Aug 30, 2015 07:26 PM
timm525
Aug 29, 2015 04:49 PM
divingmom
Aug 25, 2015 07:54 PM
