Keyless Entry Fix
Old Jan 10, 2024 | 12:54 PM
bliving7's Avatar
Default Keyless Entry Fix
I've been driving the X-300 since 95 and have had my share of trouble with the keyless remote. Recently I was able to fix two remotes. On both remotes the studs from the two battery contacts where thay attach to the circuit board had cold solder joints. I removed the old solder with some copper braid that is for solder removal. Fresh solder and all was well. Another problem was that one of the micro-switches was stuck. I put some WE-40 (sparingly) on the switch and it freed up after about thirty minutes. Circuit board are not as fragile as I've always thought.
Hope this helps someone out there.
Bill Livingston
Old Jan 10, 2024 | 07:01 PM
Parker 7's Avatar
The X300 micro switches and the rubber covers are avail on E - bay very cheap
Flex320
XJ XJ12 ( X305 )
Dec 23, 2022 05:53 AM
chater210
Mar 19, 2015 10:54 PM
simkins
Mar 22, 2012 06:17 AM
Mish_Mish
Mar 29, 2011 09:50 AM
biffta
Jan 23, 2010 03:45 AM
