Need some help - Name that bearing
Old Jan 15, 2019 | 07:10 PM
cdma's Avatar
Default Need some help - Name that bearing
My mechanic, for now until my car gets put together, told me that they need the inner and outer bearing for this part. They are telling me that they need
PART # JLM1708 INNER AND OUTER BEARING AND SEALS KIt
PART # CBC8207 COLLAR/BEARING SPACER
But a JLM1708 is a wheel bearing but based on these pictures what do they really need. The last picture has the JLM1709 next to it
Old Jan 15, 2019 | 07:31 PM
Lady Penelope's Avatar
There was a change on the wheel bearing and more important the seal on the X308 counterpart
The pic is of the output shafts in the differential itself
https://www.jaguarclassicparts.com/u...ponents-normal
Old Jan 15, 2019 | 07:55 PM
cdma's Avatar
How did I know you were the first ones to respond. Idiots told me to get the wheel bearings. That is what I was thinking it is. Just not sure which ones to get. I finally told them to get what you need. I am already into this thing for over 2.5K what's another few hundred. I have had it with these guys. Just when I thought that I finally found a good Joe to do the work.
Old Jan 15, 2019 | 07:59 PM
There is a TSB on the output shafts bearing replacement I can't find right now
Old Jan 15, 2019 | 08:21 PM
Jagboi64's Avatar
Those are the output shaft bearings on the differential. 56157C is the number etched on the bearings on the output shafts I have. Made by *** in Germany. I have seen another photo of JLM11527 (which is what you need) and the number on it is 6207-20, made by Koyo in Japan. Usually bearing numbers are quite standard, but any industrial bearing supplier should be able to get these for you, no need to go to Jaguar.
6207/C3 seems to be the common number I have seen those in SKF as well.
Those shaft assemblies are the same from the XJ40 (1987/88 XJ6) onwards.
http://www.coventrywest.com/store/ja...-jlm11527.html
Old Jan 15, 2019 | 08:48 PM
See page 7 and 35 of a doc I made a year ago
Phone number is no longer valid
File Type: pdf
Old Jan 19, 2019 | 07:57 AM
countyjag's Avatar
To add emphasis to Lady P's comments, there are an assortment of parts needed for this job, all of which are illustrated on the Jaguar classic parts site. It is not an entirely straightforward task to reassemble the output shaft correctly, and you might wish to consider whether your mechanic is up to job. I appreciate that if he already has the car apart, you may have burned your bridges already, but you should ensure that he is aware of the specific reassembly requirements.
Old Jan 19, 2019 | 08:46 AM
cdma's Avatar
Thanks for that. Luckily they have a great warranty... 2 year or 50k which ever comes last
Old Jan 19, 2019 | 08:50 AM
Brutal's Avatar
They have the wrong bearing, and you can buy pieces or the whole stub shaft assembled already to just install. Iirc
kain3488
Dec 14, 2018 01:58 PM
Jsedita74
19
Dec 8, 2012 09:37 PM
afonda
Nov 3, 2009 06:58 PM
rdcsat
Nov 16, 2007 06:20 PM
