new first time owner 95 xj6
Old Mar 3, 2009 | 07:38 PM
jth3rd's Avatar
Red face new first time owner 95 xj6
hello every one just bought my first jag
its a 95 xj6 4l loaded 80000 miles
got it for $5000 from dealer not the best deal but still under kbb
Old Mar 9, 2009 | 11:20 PM
jth3rd's Avatar
took jag out for pics Name:  save1.jpg
Old Mar 10, 2009 | 04:41 AM
Cadillac's Avatar
Congrats , hope you enjoy your ride
Old Mar 10, 2009 | 11:31 AM
jth3rd's Avatar
thanks
Old Mar 10, 2009 | 09:52 PM
jth3rd's Avatar
so far there clean
Old Mar 11, 2009 | 01:29 AM
dougs02's Avatar
Pristine looking Jag. Love the color, had one just like it for 10 years, great car and for the most part trouble free. Nice photos too. Good luck with it.
Doug
Old Mar 11, 2009 | 10:56 AM
jth3rd's Avatar
heres a good part about it has 82786miles and im the sec owner
it never has had anything replaced on it becides the basic manicanes
oil change every 5000 miles
the orignal jag tires were replace at 50529
trans filter was replaced at 60245
brakes and rotors were done 8000 ago
belts were done 300
lights 53400
heres my list of thinks to do this month
oil change
trans oil
brakes and rotors
tires
timing belt/chain
and diff oil
if im missing something please post
Old Mar 11, 2009 | 11:57 PM
dougs02's Avatar
belts were done 300
lights 53400
oil change
trans oil
brakes and rotors
tires
timing belt/chain
and diff oil
Brakes and rotors 8000 ago? Why do them again now?
Timing chains, no belt. Are they making noise? If not I would leave it alone.
Oil the hood hinges, lube the door latches.
Did the last brake job include new front wheel bearings grease?
Do you know when the antifreeze was last changed.
If you have the owner's manuals, check the charts for the 60,000 mile service and other maintenance items for time and mileage as recommended.
Doug
Old Mar 13, 2009 | 09:26 PM
1996XJ6's Avatar
Hi,
Congrats. Your Jag looks just like mine - they really could be twins. Enjoy it. Ihad mine for 2 months and its been a lot of fun!
Mike.
Old Mar 14, 2009 | 10:18 AM
jth3rd's Avatar
Doug
did change the belts and broke the pully bolt in half so had to weld and grind the bolt back together
brakes have cracks thoughout them and rotors are heat worpted
so going get drill and slotted rotors
new list
oil change $50
trans oil $45
brakes and rotors $250
tires $210
and diff oil $20
Oil the hood hinges $1
lube the door latches $1
(new front wheel bearings grease, antifreeze $70
not sure if they did those so better safe than sorry)
and make a blanket wrap for air pump, sucks not have brakes when it freezing out side for about 20 mins in till the engine heats up
Old Mar 14, 2009 | 12:04 PM
jth3rd's Avatar
and is there away to fix the fuel tank so it will fill up past 3/4
Old Mar 14, 2009 | 10:27 PM
dougs02's Avatar
new list
oil change $50
trans oil $45
tires $210
and diff oil $20
I have read several sources that drilled and slotted rotors are more prone to cracking.
Air pump has nothing to do with the brakes. Uses vacuum for the power booster behind the master cylinder. Might need to check out the brake problem further.
Doug
danpop
Sep 3, 2015 08:06 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
danpop
Aug 27, 2015 04:54 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
david5201u
Aug 27, 2015 05:42 AM
