no power......1995 XJ6
Old Mar 1, 2008 | 05:51 PM
badmojo's Avatar
Default RE: no power......1995 XJ6
How about bad o2 sensors?
Old Mar 2, 2008 | 09:57 AM
jag_genius's Avatar
well first the car only has one massive one piece cat. and i wud look inside the tank.. had plenty that the hose from the pump comes off or is only half on.. and bleeds into the tank..
Old Mar 2, 2008 | 10:05 AM
ibjags's Avatar
i had 140k 95 xj6 doing the same thing
ended up being crank sensor o/c
if you have access to known good crank sensor its worth a try
Old Mar 2, 2008 | 10:15 AM
ibjags's Avatar
you can also check crank sensor signal
good reading should be about 1.2 volt A/C while cranking engine
i"ll check and verify reading in a few
check when cold and then recheck when fault occurs
Old Mar 2, 2008 | 09:41 PM
ibjags's Avatar
ive seen it a few times on 95 to 97 xj"s
and even more so on earlier models 88 to 94
King Charles
Oct 16, 2015 01:25 AM
trickeyM
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
baskervillema
Oct 1, 2015 06:43 PM
dansxj6
Sep 28, 2015 08:02 AM
