OBD not reading
Old Aug 19, 2022 | 07:54 PM
jomo's Avatar
Default OBD not reading
On my 1995 xj6 I wanted to see why my check engine light was on. I tried my scanner first, one at advanced auto parts and two at auto zone and none of them were able to get a reading. I checked all my fuses (left/right engine bay, left/right heel and the fuse box in my trunk) right after I did not get a reading and they all are fine. I have no idea what to look at next.
Can some please tell me which pin(s) should be getting 12v.
Thanks!
Old Aug 19, 2022 | 08:17 PM
xalty's Avatar
$5 elm327
many scanners struggle with early, barely compliant cars
Old Aug 19, 2022 | 08:25 PM
jomo's Avatar
xalty,
Thanks for responding. I understand what you are saying but in the past my scanner has worked on this car so I think it is a different problem then you are describing.
Old Aug 19, 2022 | 08:34 PM
Parker 7's Avatar
there is a fuse and someone found one of the pins bent in the OBD 2 socket
The fuse is shared with the fuel pump relay pulling coil halve so if you have that ....
The fuse is if I recall in the right heelboard fuse box different then the muscle power fuel pump relay fuse in the trunk........
Old Aug 19, 2022 | 08:35 PM
Parker 7's Avatar
specified to the scanner your car model ?
Old Aug 19, 2022 | 09:14 PM
jomo's Avatar
I will check the pins tomorrow. I actually suspect that maybe one or more are loose.
Old Aug 20, 2022 | 09:02 AM
Parker 7's Avatar
3 double hash stopsign is a ground through the ignition switch
and
103 square is # 6 / 5 amp trunk fuse box , this passes through the BT4 connector which can be a pain to reconnect above the fuel tank
and
the before mentioned # 10 / 5 amp right heelboard fuse box
And
# 7 double hash circle is the fuel pump relay control
kingnero
May 4, 2020 03:48 AM
Salu498
Nov 9, 2018 10:01 AM
omgimali
Nov 2, 2016 04:37 PM
cygnus x1
Apr 15, 2015 03:42 PM
Wife's Tech
Mar 8, 2015 11:27 AM
