oil drain plug
Old Aug 26, 2018 | 09:16 PM
jomo's Avatar
Default oil drain plug
Hi,
Can some please tell me the size of the drain plug for a 95 xjs and a 96 xj6 as I can't seem to find this information anywhwere.
Thank you
Old Aug 27, 2018 | 04:27 AM
kingnero's Avatar
This one is mine, can't however say for sure it's the original part.
You'll also want a copper washer inside diameter 21 mm.
Old Aug 27, 2018 | 05:10 AM
That looks right for OE.
Careful when tightening. Stripped threads can lead to a very exciting weekend!
This one came from the PO with a leaking plug.
Old Aug 27, 2018 | 05:45 AM
Vee's Avatar
Vee
That’s the part alright! No need to go overboard on the tightening, it will make removal in the future more difficult than it needs to be...
My washer is a zinc washer with some rubber gasketing material on the inner diameter....sure they all do the same job.
Old Aug 27, 2018 | 05:49 AM
kingnero's Avatar
LOL. I could easily take a picture of mine, because I've retapped my oil pan for a larger size... Was siliconed shut when I bought it.
Old Aug 27, 2018 | 08:39 AM
Lady Penelope's Avatar
Raook me 8 days of penitratimg oil ad heat
Old Aug 27, 2018 | 10:18 PM
jomo's Avatar
Can someone please tell me the thread sizes for the oil drain plug for the 95 xjs and 96 xj6
Old Aug 28, 2018 | 09:50 AM
Vee's Avatar
Vee
M20x2.5
Old Aug 28, 2018 | 10:27 AM
Ric in RVA's Avatar
Originally Posted by Vee
M20x2.5
I can't even imagine what prompted them to use such a huge plug with such coarse threads in an aluminum pan with no structural requirements except to hold back some oil.
It is just comical.
Old Aug 28, 2018 | 12:05 PM
kingnero's Avatar
It is just comical.
from a mechanical viewpoint, the shear surface is the same for a coarse as for a fine thread (with a slight advantage for the fine thread), and a coarse thread is harder to cross thread.
Not such a bad choice after all, I'd say...
But I agree, most other oil pans I've seen have M14 or smaller as an oil drain plug.
Old Aug 28, 2018 | 01:25 PM
motorcarman's Avatar
You can drain 9 quarts of oil pretty fast with a 20mm hole but they should have used a 13mm hex head on the bolt to lessen the chance of over-torquing!!!!
bob
Old Aug 30, 2018 | 03:46 PM
rod_f's Avatar
fall4it
XJ40 ( XJ81 )
Jun 8, 2008 09:58 AM
snooktarpon
May 17, 2008 07:43 AM
ikeholt40
Nov 3, 2007 01:06 AM
ikeholt40
Nov 2, 2007 12:41 PM
