Post brake job issue
Old Feb 20, 2023 | 03:55 PM
Tbilisi79's Avatar
Default Post brake job issue
So I had both front pads changed and one caliper.
It feels like the brake pedal travel is a lot longer now. I went back tot he shop and asked if they bled the brakes. They said they did. I left the car again for them to look over.
They assured me they bled the brakes and said I have to break in the pads.
I trust this shop, they have done work on other cars with no issues. But To me it feels like there is a lot of air in the system.
What am I missing here?
Thank You.
Old Feb 20, 2023 | 07:35 PM
Parker 7's Avatar
To properly bleed the brakes you must bend the drain hose in a U shape to not have air going back into the calipers.on pedal pumping action
A straight hose will allow air back in and no hose is the worst thing you can do
Old Feb 21, 2023 | 01:50 PM
Tbilisi79's Avatar
Got it
Thank you.
Old Feb 21, 2023 | 01:54 PM
Tbilisi79's Avatar
Do I need to bleed rears as well or just fronts? Not sure of the brake booster setup.
Old Feb 21, 2023 | 03:05 PM
Parker 7's Avatar
There is a large X300 6 part service manual I uplaoded and will find the link
lookong
Old Feb 21, 2023 | 03:19 PM
Parker 7's Avatar
see post # 4
Repair Manual - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 21, 2023 | 06:07 PM
Tbilisi79's Avatar
Oh wow!! Thank You!!
Reading material for the week. Tea time
Old Feb 21, 2023 | 07:47 PM
Parker 7's Avatar
I don't know if it covers your spot of stumble.
But your saga made me stop for a bit of weep
Old Feb 22, 2023 | 08:45 AM
Larry Louton's Avatar
I have seen a left brake caliper placed on the right and vice-versa. You will end up with both bleeder screws pointing downward which is impossible to bleed. If the one brake caliper piston was seized, You will get a high pedal because you can't move the piston. Take photo of new caliper with wheel off for us to see please. Were new hoses installed?
Larry Louton
Old Feb 22, 2023 | 06:17 PM
Tbilisi79's Avatar
Larry Louton
Thanks for chiming in.
The pedal has a bit longer travel now. Brakes start grabbing right awa but you need to travel more down the pedal travel to get more braking.
Only the passenger side caliper was changed. And pads Nothing else
Brewtech
May 21, 2020 02:17 PM
malbec
Nov 8, 2019 02:34 PM
wymjym
Nov 12, 2018 08:21 AM
jonny747
Dec 11, 2011 05:01 AM
CountyCorvette
Nov 10, 2009 09:21 PM
