Experiencing classic symptoms of power steering pump failure (noise and corresponding vibrations in the steering wheel when turning [at a stop & while in motion], shuddering hydraulic assist during some maneuvers [like u-turns] and having a hard time with the following:
[1st] Figuring out which pump I need. I downloaded the digital parts catalog, and none of the images are remotely close to what RA is showing at pump replacement.
[2nd] Determining if this repair is within my mechanical ability.
Not finding much information on either. 1996 VDP 125k
TSBs are your friend. Here are some (that nobody reads) that I uploaded to this site years ago.
bob
Apologies motorcar man, and thank you for sheding some light. I ALWAYS start these endeavors for information by utilizing search functions within these forums. If my spefic search comes back unsatisfying, I broaden the search criteria and repeat until I discover new search criteria specific to my application.
Searching entire X300 forum using keywords: 'power steering' was a disappointment. I did stumble on the TSB for the drive dog removal tool that you have linked when I Google searched the p/n for power steering pump that shows on rock auto.
