Power steering pump replacement
Old Apr 6, 2019 | 08:27 AM
EppNation's Avatar
Default Power steering pump replacement
Experiencing classic symptoms of power steering pump failure (noise and corresponding vibrations in the steering wheel when turning [at a stop & while in motion], shuddering hydraulic assist during some maneuvers [like u-turns] and having a hard time with the following:
[1st] Figuring out which pump I need. I downloaded the digital parts catalog, and none of the images are remotely close to what RA is showing at pump replacement.
[2nd] Determining if this repair is within my mechanical ability.
Not finding much information on either. 1996 VDP 125k
Old Apr 6, 2019 | 08:46 AM
Lady Penelope's Avatar
Have you tried replacing the fluid ( in all of it ) as it wares out and cavitates in front of the pump
Worked for me
Old Apr 6, 2019 | 09:28 AM
motorcarman's Avatar
TSBs are your friend. Here are some (that nobody reads) that I uploaded to this site years ago.
bob
File Type: pdf
File Type: pdf
Old Apr 6, 2019 | 09:30 AM
EppNation's Avatar
I'll certainly give that a try first! Thanks for the suggestion!
It as simple as disconnecting a return line and sticking it in a drain pan and keeping reservoir full until collected fluid turns runs clean?
Nothing ever seems simple with these cars...
Old Apr 6, 2019 | 12:36 PM
Yes , remove the hose at the pump input ( with the car not running ) and drain the reservoir then refill
This will " refresh " 1/3 of your fluid
Drive the car a while to mix the old and new fluid
Do it again and you will have X refresh and so on
engine turned over with starter option ?
Buy the large fluid bottles
Old Apr 6, 2019 | 12:58 PM
EppNation's Avatar
bob
Apologies motorcar man, and thank you for sheding some light. I ALWAYS start these endeavors for information by utilizing search functions within these forums. If my spefic search comes back unsatisfying, I broaden the search criteria and repeat until I discover new search criteria specific to my application.
Searching entire X300 forum using keywords: 'power steering' was a disappointment. I did stumble on the TSB for the drive dog removal tool that you have linked when I Google searched the p/n for power steering pump that shows on rock auto.
Old Apr 6, 2019 | 01:03 PM
I added a TSB (10-08) and removed one that did not apply (10-10am3).
bob
Jacob67
Apr 20, 2019 06:17 PM
sunchip
Jan 28, 2015 08:21 AM
MarcB
Jan 16, 2012 10:29 AM
Bruce in North Dakota
Jan 9, 2010 08:07 AM
