programming a remote transmitter fob
Old Oct 25, 2010 | 09:27 AM
sempire's Avatar
Default programming a remote transmitter fob
I have a new keyfob for my '97 VDP and need to program it. I remember seeing the process somewhere how todo so. Does anyone here have this information to provide me, I can't remember where I have seen it previously.
Old Oct 25, 2010 | 10:50 AM
xjrguy's Avatar
Here is a cheat sheet I made several years ago!
File Type: pdf
Old Oct 25, 2010 | 10:54 AM
mailshack's Avatar
Hello sempire.
I have been looking for a keyless remote myself and have yet to obtain one, so I can't vouch for these instructions...but take a look here:
http://www.jagbits.com/reprogram.html
Post back; I'll be curious to see how it goes for you!
Bob
...just saw xjrguy's response after hitting 'post reply' on mine. There you go!
Old Oct 26, 2010 | 05:14 PM
sempire's Avatar
Thanks guys! I will give it a try!
Old Oct 27, 2010 | 04:30 PM
sempire's Avatar
looks like it didn't work. went into training mode but after that looks like it didn't work. the central locking doesn't look like it works anymore either..
Old Oct 27, 2010 | 09:27 PM
motorcarman's Avatar
I think that these TSBs need to be posted as permanent.
I will post them again!!!!!!
bob gauff
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 27, 2010 | 11:48 PM
My fault Bob, they are permanently posted on the forum, I just did not include the link from the TSB thread at the top of this section. (date issue).
This has now been rectified, many thanks again.
TSBs.
Old Oct 28, 2010 | 08:22 AM
sempire's Avatar
I have read those, and replaced the batteries. I do get the LED's blinking. The car goes into training mode no problem. I have the right frequency remote, but still when I hit the arm button when programming. i get no beep.
Any other suggestions? Is there a way to confirm the antenna is hooked up?
Old Jan 13, 2011 | 05:48 PM
tobe111's Avatar
Default fob programming
There is a great video on youtube for programming the remote...worked for me. Just search jaguar x300 fob.
Old Sep 1, 2011 | 10:02 AM
Wiired's Avatar
Thumbs up
Originally Posted by mailshack
Hello sempire.
How to re-program your keyless entry remotes 1990-1996 XJ6s
Bob
Just followed those instructions you posted today to reprogram my remote after the batteries died. The directions were simple and easy and it worked perfectly!
Thanks for this post, really appreciate it! Now that I know it works, I can buy the second remote on eBay that i was looking at; I wanted to be sure that I could reprogram myself before buying it. The dealer I called wanted $150 to do what took me less than 2 minutes thanks to you!
Old Sep 6, 2011 | 06:53 PM
mailshack's Avatar
sempire,
Did you ever get your fob to do as it should?
Old Sep 6, 2011 | 08:29 PM
Wiired's Avatar
Sempire, just curious, when you changed the batteries in your remote did you use 2 x CR2016's or a single CR2032?
Reason I am asking, I was in your predicament; my batteries died and I did not have any of the 2016's, but I have a bunch of new 2032's which are essentially the same battery, just twice as thick. Since the voltage was the same, I replaced with a single 2032 instead of the 2 x 2016's; It would not register the remote, and I also was successful in getting it into learning mode. The lights were blinking normally on the remote as well. I went out and got the 2 x 2016's and it worked like a charm.
Old Sep 7, 2011 | 07:00 AM
sempire's Avatar
It's been so long that I can't remember anymore. I ended up selling the car shortly after. The instructions seemed to work though..
I'd really love to get my hands on another jag though...
Old Sep 7, 2011 | 08:48 AM
You need to have 6V with the 2 batteries in series. If you use a single 2032 you will only have 3V and it won't work.
bob gauff
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
zdrapec
Sep 25, 2015 05:49 AM
