PSA: lower shock bushing removal
Old May 9, 2022 | 05:02 PM
xalty's Avatar
Default PSA: lower shock bushing removal
lots of people don’t like doing this job. the truth is with a poly bushing this is laughably easy.
you can remove these bushings in less than 3 minutes. walk the rubber out with a drill and hacksaw the shell out.
press the polybush in with some bolts and a washer you’re done.
Old May 9, 2022 | 05:58 PM
watto700's Avatar
G'day Gents,
Another idea, I have used this arrangement several times over the years to remove and replace the bottom front shock bush. A high tensile bolt, a socket, a piece of pipe and several washers. Once the bush has 'cracked' it slides out of the suspension arm quite easily.
I had a lot of trouble with the OEM bushes wearing out so I replaced the rubber with a polybush using the inner and out metal parts of the OEM bush and finding a polybush that I could press into the outer shell and then press the inner metal part into that. I did this well over ten years ago and haven't had to replace the bushes since.
Cheers,
Jeff.
Bob Boyle
Nov 25, 2020 06:55 PM
stham
Apr 7, 2019 11:37 AM
Jon89
16
Jan 18, 2017 02:10 PM
SilverXJ
Feb 29, 2016 03:26 PM
SirJag
Jul 2, 2012 10:38 PM
