Radiator Panel Hex screw stripped.
Old May 14, 2020 | 05:05 PM
Tbilisi79's Avatar
Default Radiator Panel Hex screw stripped.
I wanted to change the radiator bushings, so I soaked the hex screws with some WD40 and 4 hours later I tried to take them out. Well 3 of them did not want to come out and the the hex is now ruined.
I got a small kit from Home Depot to extract the screw but that didnt work and it didnt bite.
So I can either get another kit to remove the screws, or take it to the shop close to me and ask them to remove the screws in question.
I really wanted to do this task myself.
Any thoughts?
Old May 14, 2020 | 05:20 PM
Parker 2's Avatar
The bolt head must have a pilot hole drilled first
The short stubby easy outs are cheaper but in practice they don't stand up straight as you crank
The bolts can be quite rusted on the threads
In spraying with penetrate the oil gets under the head but not necessarily the rusted threads
You can drill the heads off to be able to get penetrate on the threads but I can't remember if the remaining shank is tall enough to extract with vice grips negating the meed for a easy out
You can source some replacement bolts from a later model V8 powered X308 at the salvage yard , the heads I think are different then the torque bits used on the X300
Old May 14, 2020 | 05:23 PM
The torx screws (item 4) fixing the top radiator mounting panel (item 1)?
The are standard M8 torx screws and widely available. I'd get replacements and either drill them out or remove them with a stud extractor.
Old May 14, 2020 | 05:26 PM
motorcarman's Avatar
WD40 (Water Displacement 40) is not really a penetrating oil.
Please try a proper penetrating oil like KROIL or PB Blaster, Liquid Wrench etc.
I would use 'anti-seize' when reinstalling bolts when you get this sorted.
bob
Old May 14, 2020 | 05:53 PM
watto700's Avatar
G'day Tbilsi,
If you can't get the rusted bolts out you might have to drill them out and use a Helicoil https://helicoil.in/ to repair the damaged threads.
Cheers,
Jeff.
Old May 15, 2020 | 06:57 AM
Tbilisi79's Avatar
Thank you all. Its two in front of the radiator and one main on on the side.
Even if half of them go back for the time being I think the radiator will be held in place just fine. Gonna get the screw extractor tool today. Will post results as the day goes.
Old May 15, 2020 | 07:08 AM
xalty's Avatar
They’re all torx. I stripped one thread on removal but never the head, be careful.
Old May 15, 2020 | 02:18 PM
Tbilisi79's Avatar
Had the shop take out the stripped hex screws with ease. The rest I did myself, changed the bushings.
Car is like new now.
Vee
Mar 30, 2020 10:04 AM
Panelhead
Aug 18, 2019 10:14 PM
Shahar Alon
Sep 6, 2018 03:46 AM
Clayxj
Apr 13, 2018 03:25 AM
rgp
Dec 8, 2016 03:13 AM
