Reach Motor Cable Replacement
Old Mar 23, 2014 | 10:06 AM
knealy2's Avatar
Default Reach Motor Cable Replacement
After searching and reading three different threads on this subject and still have some questions, I decided to go ahead and attempt this repair. Reach motor cable is available at Jaguar Parts, Land Rover Parts, Mini Cooper Parts
My reach motor cable was broken with the column all the way in, so I determined the only way to access the motor was to drop the whole column. Some have said that you can access it by removing the instrument cluster (which may be possible), but I really didn’t want to go this route.
After removing all of the trim panels you are left with just the column (Picture 1).
Remove the two T40 Torx bolts (Picture 2), you will need a long extension for you socket wrench.
Remove 1 bolt and 1 nut at base of column at floor board (Picture 3).
Disconnect all of the cables and drop the column (Picture 4), and you can then access the reach motor (Pictures 4, 5, & 6).
The motor is held in place with two cable ties that will need to be cut and replaced once new cable is installed (Pictures 7 & 8).
Remove the motor by pulling straight up from the plastic “C” clamp that holds it to the column (Pictures 9 & 10).
Pull the old cable out of the motor, don’t forget to make sure you get all of the pieces, mine was broke in two and replace with the new one (Picture 11).
Reassemble in reverse order.
I turned off the auto memory adjustment to prevent the cable from breaking in the future, as I believe the reason so many of these break is because the travel sensor goes bad.
Hope this helps someone out there as pictures always made things easier for me!
Cheers,
Ken
Attached Thumbnails Reach Motor Cable Replacement-reach.jpg   Reach Motor Cable Replacement-reach1.jpg   Reach Motor Cable Replacement-reach2.jpg   Reach Motor Cable Replacement-reach10.jpg   Reach Motor Cable Replacement-reach11.jpg
Reach Motor Cable Replacement-reach8.jpg   Reach Motor Cable Replacement-reach9.jpg   Reach Motor Cable Replacement-reach3.jpg   Reach Motor Cable Replacement-reach4.jpg   Reach Motor Cable Replacement-reach5.jpg
Reach Motor Cable Replacement-reach6.jpg   Reach Motor Cable Replacement-reach7.jpg
Old Mar 24, 2014 | 10:03 PM
Scotlad's Avatar
I do not have a XJ6 but I have been wondering about these steering column cables that go bad. I was surprised to see that it is actually a threaded rod. Would you know what the diameter and pitch of the rod would be? Did you happen to notice in photo#9 that the thrust bearing up against the white bushing does not look too healthy, it looks like one or two of the ball bearings are missing. I work with bearings quite a bit and when you see a grey metallic paste where a clean grease should be, that is usually not a good sign. Thanks for the great write up, photos do make a difference.
Old Mar 27, 2014 | 10:41 AM
mgb4tim's Avatar
Do you really need to remove the steering wheel?
Old Mar 27, 2014 | 12:18 PM
sogood's Avatar
No, but when you drop the steering column, it can get in the way. I would however, recommend removing the airbag set up. Disconnect the battery, leave it alone for long enough to have a coffee and then you're good to go. Apparently it takes time to discharge the electrical system fully, so, better safe than sorry.
Old Mar 27, 2014 | 04:51 PM
mgb4tim's Avatar
I'm going to try to do it without the wheel. Ordered the shaft today.
Going to recover the visors and add a homelink module to the driver's side over the weekend, hopefully.
When I'm done with that I'll drop the column, and let it sit without the battery connected until the shaft shows up.
Old Mar 27, 2014 | 04:56 PM
knealy2's Avatar
You don't have to remove the steering wheel (had it off to refinish).
Old Mar 27, 2014 | 05:02 PM
knealy2's Avatar
Sorry Scotlad, don't know the measurements you are looking for.
It did appear to be missing 1 bearing, but could find nothing in the little chamber the sleeve fits in, and really nowhere for it to go if it fell out? Just cleaned and re-lubed it.
Old Mar 30, 2014 | 06:11 PM
mgb4tim's Avatar
OK, dumb question... How does the top of the steering column cover come off. The bottom came off with 2 screws. Doe the top just snap on?
I also saw another thread where they pulled off the gauge cluster. They pulled from the top center to release a clip... but then what?
Old Mar 30, 2014 | 07:17 PM
knealy2's Avatar
Once you remove the lower cover, you will have access to the 3 screws that hold the top cover on (they are really up in there!).
Not sure about the cluster, as I did not remove it.
Old Mar 30, 2014 | 08:23 PM
mgb4tim's Avatar
Well, I never found the third screw for the top cover, but I did find the four tiny screws that hold the dash cluster in place.
So, with that said, the column is dropped, the shaft is replaced, and has been tested.
I'll button it all up tomorrow.
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
