Rear suspension work
Old Jun 14, 2023 | 04:34 PM
Todd Wiens's Avatar
Default Rear suspension work
Hello,
I am looking at replacing my rear shocks and the spring insulators.
Do I need a spring compressor to do this job?
Old Jun 14, 2023 | 06:42 PM
Parker 7's Avatar
Someone made a good Youtube video on X300 model mater
Motorcarman ( Bob ) has a shortcut involving the lower plate
The rear shocks may have a lower attach point solid bushing that should be considered
Old Jun 14, 2023 | 06:48 PM
Parker 7's Avatar
Someone made a good Youtube video on the matter
Motorcarman ( Bob ) has a shortcut involving the lower plate called the
Suspension subframe as item # 13
Genuine Frame Carrier-rear For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
See item # 17
Genuine Damper And Spring Fittings-rear For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
and
What that attaches to can't recall
Old Jun 15, 2023 | 12:38 AM
SleekJag12's Avatar
The short answer is NO. But there are several different ways to approach the job, mostly documented in here. Some have used compressors.
I found it relatively easy to undo the body mount in front of the wheel, loosen the rear center of the subframe, take the brake caliper off and let the axle/A-arm drop low enough to let off the pressure on the lower shock bolt and the spring. Then you can muscle out the spring/shock assembly. You can do one side at a time this way.
Old Jun 15, 2023 | 01:05 AM
Parker 7's Avatar
I never could find the video that appeared as a post
I have not done the job
Autozone and other auto parts stores have tool kits including 2 types of professional robust spring compressors to use for free if you go that route
I used the spring compressors kit on some other unworthy car other than the Jaguar
Old Jun 15, 2023 | 02:24 AM
bjarnetv's Avatar
here is a video of one method
OCDHerb
E type ( XK-E )
Nov 2, 2022 04:28 AM
Stu Jags
Jul 9, 2019 01:28 AM
Moodieblue
XJ40 ( XJ81 )
Dec 4, 2013 08:28 PM
JPM50
Aug 6, 2012 08:35 PM
eric7216
Mar 20, 2012 02:31 PM
