Rear window Sun shade for the X300?
Old Jun 28, 2014 | 06:54 PM
al_roethlisberger's Avatar
Question Rear window Sun shade for the X300?
So, it appears that there are two "hooks" in the headliner right above the rear window what I would assume are for a rear window Sun shade?
I know a rear Sun shade wasn't a factory option on the USA spec X300 XJR, but I wondered if perhaps it was a dealer option, or on the VDP, aftermarket, or available in other markets??
Anyone know if a factory/dealer rear Sun shade was available, or if there is/was an aftermarket unit?
Old Jun 28, 2014 | 07:02 PM
Chattanooga_XJR's Avatar
I was looking into that but I've decided to get tinting done, car gets so darn hot and baked in the sun since I don't have a garage for it at the moment. Going with a lesser tint on the front windscreen as well.
Old Jun 28, 2014 | 07:20 PM
Lightbulb
Yeah, my rear window and all sides are tinted. And it does help quite a bit.
I'm not usually a fan of tint, but a previous owner had it done and it seems to be a high quality job at least.
But I'd like to still protect the rear deck and seats some more than the tint alone, and of course a lot of Sun comes in through the rear window given its angle.
Since the hooks are there, I thought it might be nice to find the shade.
And on that note, it looks like there was a factory option...
Jaguar XJ 86 94 Rear Window Sun Blind Shade Sunblind Sunshade XJ40 XJ6 | eBay
Not sure if this is a direct bolt-on for the X300, but it was for the XJ40. Clearly the "hook bar" wouldn't be needed on the X300, and not sure if the holes are there on the X300 deck, but it would be cool if this could be mounted with no modifications.
Anyone know if this is a direct fit for the X300?
Old Jun 28, 2014 | 07:33 PM
And here's another one.... guess I should have "Googled" even longer...
Backlight glass sunblind - Jaguar-Shop.com
Says it won't mount when one has premium sound (subwoofer), but I bet one could make mounting spacers to clear the speaker.
Old Jun 28, 2014 | 07:54 PM
b1mcp's Avatar
If you have premium sound system there is a different shade that comes in LH and RH parts.
You can get a lot of information about these cars from the parts catalogue that is available on line.
Parcel Shelf and Sunblind - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
Old Jun 28, 2014 | 08:26 PM
Don B's Avatar
That's a great find, b1mcp.
jaguarclassicparts.com is the parts service of the Jaguar Daimler Heritage Trust and is a great resource.
You can also download the Jaguar Electronic Parts Catalog from the "X300 'HOW TO' quick links" on the home page of this forum. Install the EPC on your computer and you can view the same information for models from the Series III through the X350 even when you don't have Internet access.
Cheers,
Don
Old Jun 28, 2014 | 08:35 PM
Yeah, I had just dropped them an email. It may not be available anymore, but I bet one could modify the non-premium sound version with some spacers to lift it above the subwoofer grill.
Old Jun 29, 2014 | 06:44 AM
Maraud's Avatar
I have removed my sunshade a couple of times to repair it. there are small white pins on each side that hold the end so the slide+spring wont come out of the metal case. these pins and the plastic attachments break very easily. I know that the underside has 3 moveable pins in a slide. Left, middle and right. These can be removed by removing one of the stop blocks at each end, very easy also. So in theorie you could replace these pins with a larger one and add spacers to lift it above the grill.
The pins are like a screw with a flat thin square head, that is hold in the slider.
Old Jul 3, 2014 | 05:48 AM
AL NZ's Avatar
my Daimler Six has the sunshade (one piece, std sound system).
I put big 66 1/2" spekers in my parcel shelf, and had the Daimler parcel shelf and blind removed, replaced with a 'plain' shelf out of an X300 Jaguar (no blind) which I was happy to cut holes in for the speakers.
I have the Daimler blind/shelf tucked away and it can be swapped back
Old Jul 31, 2015 | 04:41 PM
BTW, picked up a pair of used rear shades from the UK, so now I'm researching how to install them. They don't seem that common on US cars interestingly as I had no luck finding any.
And yes, for "Premium Sound" equipped cars (with the rear package shelf sub-woofer), the shades/blinds are two parts, a LH and RH shade/blind.
The one-piece shade/blind only fits cars without the sub-woofer.
Old Apr 30, 2021 | 10:52 AM
Korhan Durusoy's Avatar
Default Rear eindow shade
Do it fit Xj6 1996
Old Apr 30, 2021 | 07:56 PM
Don B's Avatar
Hi Korhan,
Welcome to the Jaguar Forums! It's great to have you with us.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome. Also, note that the thread to which you have posted has had no activity since 2015.
Cheers,
Don
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
