Removing ignition coils / spark plugs
Old Dec 31, 2012 | 06:21 PM
Dan Bennett's Avatar
Default Removing ignition coils / spark plugs
Any trick to doing this on my 96 VDP? I have a misfire that I'd like to take care of as quickly (an cheaply) as possible since I just put a new converter on it a couple months ago and don't want to double my expenses.
I took the cover off with the T27 (3 screws) and see the leads but not sure if I can just pry them off from the top with a screwdriver or something (to confirm if a coil or plugs are the problem).
I'm 35 years old and not a mechanic , however, I am not afraid to learn anything. Just haven't felt compelled until I bought this old gem......
Any tips or links would be greatly appreciated!
Also, can someone tell me (should I need a new coil):
1. Should I REALLY buy a whole set? I mean will I possibly do the car any justice by putting them in now? I'm thinking if I am able to do them myself, and they are working, they are working?
2. Does it really matter if I get the $200/each version or the $$50-60 version everyone seems to sell that doesn't have jaguar in their url?
Thanks a bunch!
Old Dec 31, 2012 | 06:30 PM
plums's Avatar
moved to x300 section
Old Dec 31, 2012 | 07:48 PM
Suede's Avatar
Dan,
The coils simply pull off after you loosen the 2 8mm bolts securing them. Beneath the coils are rubber boots which seat on the spark plugs themselves. Coil replacement is truly as simple as replacing a light bulb. Just unbolt, pull out, put in new coil, and rebolt.
You'll get responses all over the map re: "Factory" or "Cheap" coils. My philosophy is: If I get 100,000 miles out of a cheap coil, vs 150,000 out of a factory coil is it worth the $150 savings? For me it's a no brainer. It's a part that's easily replaced in 5 minutes, so $50 cheapies just make the most sense. I'd purchase 2 cheapies, & sit one of em in the trunk so I've a spare with me if another fails.
Old Dec 31, 2012 | 08:26 PM
Doug's Avatar
Eighteen months ago I bought four cheapie coils (Beck Arnley) and a couple months later two more of them same. All six of those have failed.
Of the six failed coils four failed within the twelve month warranty and were replaced. That leaves us with four replacements and two from the original purchase. Of those, five have failed. The only remaining BA coil is one of the warranty replacements.
So, if you buy the cheapies my advice is to buy extras to carry in the car and the tools needed to replace 'em by the side of the road. That's what I ended up doing. Cheap or or not, the fun and adventure of this drill sorta begins to wear off after a couple times.
Until recently I have been using used Lucas coils (typically getting a few months life out of them) but thanks to a sharp fellow enthusiast who pointed me in the right direction I've bought a couple of these, one is on the car and the other to have on hand in preparation for the inevitable failure of the last remaining BA unit:
Jaguar XJS XJR XJ6 Ignition Coil 95 97 | eBay
Judging from the labels these are the exact same manufacturer as the so-called "Lucas" coils so I'm hoping they'll last a few years. If so, the extra $50/each is well worth it.
Genuine "Lucas" replacements from Jaguar, in a Jaguar box, are now over $400/each which is stupid-expensive by anyone's measure.
PS- I should add that the last coil failure I had (with the typical crazy gauges and Tokyo-at-night flashing warnings lights) seems to have created another problem. *Immediately* after the last failure episode my ABS warning light is on at all times.
Old Dec 31, 2012 | 08:28 PM
Doug's Avatar
Buy at least three. One for the car, two for the trunk !
Old Dec 31, 2012 | 10:08 PM
doc's Avatar
doc
I originally bought the cheap ones they didn't last 15,000 k,s or 2 years only 2 went this time
I decided to get a full set again this time I got them from these guys Ignition Coil - LHE1510AB | Jaguar X300 - XJR, Jaguar XJS | Jaguar | British Parts UK They where pretty quick getting them to Australia only took 4 days also these coils had made in Japan on them and looked like the originals
I'll tell you how they last in the next couple of years I have already done 15,000 k,s on them
Old Jan 20, 2013 | 02:44 AM
Canuck XJR6's Avatar
I was just about to go out to the garage and change all 6 coils with ones bought from British Parts UK (the same ones as Doc bought) when I read this thread!
The XJR6 has 82K Miles on it and since I've only done the last 2K Miles I though I'd be nice and replace the coils and spark plugs. It idles little bit rough sometimes after starting and on the highway at a constant speed with cruise control set it will have a bit of vibration at different times on the road. (May have a bit of balancing to do but since the vibration is intermittent at the same speed but possibly under different loads I though I'd try the coils as well)
Is there a way to tell if a coil is bad without some type of tester/computer and do you guys think I should replace all the coils anyway because of the millage?
Thanks for any advice!
Chris
Old Jan 20, 2013 | 09:24 AM
Doug's Avatar
Chris
The only test I know of is to measure primary resistance ....between the two connector pins....which should be .75 OHM.
From experience I've learned that this test is of limited value. A coil that passes a "bench test" with correct resistance may fail while driving. And I've had some coils with high resistance that worked perfectly well....right up to the point that they didn't.
If you suspect a coil is flat-out, 100% inoperative checking primary resistance may indentify which one it is. Unfortunately, 100% inoperative is not the usual failure mode of these coils.
I'd install your new ones and save the old ones as spares. You might need 'em one day.
Old Jan 20, 2013 | 12:10 PM
Thanks for that Doug!
I'll swap them out and post back to let you know how it went and if I have noticed any improvement. New "Lucas" stamped coils to go in and old ones to come out and tucked safely away for a rainy day.
Cheers from Dubai,
Chris
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
avern1
Sep 8, 2015 06:25 PM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
