Replacement radiator for XJR6?
Old Dec 7, 2015 | 11:30 AM
andyXJR's Avatar
Default Replacement radiator for XJR6?
I need to source a replacement radiator for my 1996 XJR6. It seems that Jaguar don't produce any such parts so, I wondered, does anyone know about a third party who manufactures a copy of the original?
Old Dec 9, 2015 | 06:30 AM
knightofgold's Avatar
I actually have one I pulled from the salvage yard. But it might be prohibitively expensive to ship to GB.
Old Dec 9, 2015 | 07:17 AM
dfieldsend's Avatar
Suggest you contact these guys, have not had a jag one from them, but they do come highly recommended for other marques.
JAGUAR RADIATOR from Aaron Radiator Co, London, UK - Jaguar Car Radiators
Old Dec 9, 2015 | 12:01 PM
countyjag's Avatar
The only difference between the XJR radiator and the other X300 radiators is the connections for the transmission oil cooler pipes. On the XJR, the radiator couplings are female whereas the others are male. Potential solution number one is to source an "ordinary" radiator, which is relatively easy to do, and fit a converter coupling to attach the transmission oil cooler pipes.
Potential solution number two is to have your existing radiator recored. My local radiator repairer did this for £195, replacing the aluminium core with brass, and using my existing plastic end tanks. Took them a day, and I am very happy with the results.
If your XJR is a manual, any X300 radiator will work.
Old Jun 20, 2016 | 09:07 AM
andyXJR's Avatar
Many thanks for your thoughts - I've only just read this...! Could you PM me details of who did the recoring? Sounds like a rather sensible way forward.
Old Jun 20, 2016 | 03:35 PM
AL NZ's Avatar
Andy, for what it's worth I had a new aluminium radiator made for my 3.2 last year after a plastic pipe on the original radiator broke
It has been a saga- first of all the left off the connectors for the auto gearbox oil cooler, so it went back. Then it started to leak and was repaired. Now it has anothe slow leak. They tried to blame the car for having a stray current and causing electrolysis of the aluminium but I had it tested and that isn't the problem
Old Jun 20, 2016 | 03:52 PM
countyjag's Avatar
It was a little local place here in Edinburgh. They put a brass core in, which I think is much easier for them to work with.
If it is feasible for you to send a radiator here, let me know, and I can dig out the details.
Old Jun 22, 2016 | 05:27 AM
andyXJR's Avatar
Yes I could at sending to Edinburgh. Could you PM some details?
Old Jun 22, 2016 | 04:43 PM
rod_f's Avatar
Radiator recoring is a relatively common service if you didn't want to deal with an Edinburgh outfit by post.
No idea what these people are like but it's local (Odiham):
Bagshot Radiator Services - Radiator Repair Specialist for Hampshire, Berkshire and Surrey
Old Jun 24, 2016 | 05:34 AM
countyjag's Avatar
Andy,
I pmd the details to you
dennis black
Dec 28, 2015 08:56 PM
littleguy
XJ XJ12 ( X305 )
Dec 17, 2015 04:11 PM
Richter12x2
Nov 18, 2015 09:20 AM
jimateo
Nov 15, 2015 08:13 PM
64vette
Nov 13, 2015 07:57 PM
