Replacing clock
Old Feb 25, 2011 | 03:55 AM
biffta's Avatar
Default Replacing clock
Like many owners my clock display died quite some time ago. I once tried to effect a repair following advice from others who had restored the display, but I failed miserably and I suspect rendered the thing totally unrepairable by anyone!
My unit has the basic clock display with a button on its left - 'Lock' and another on the right of the display for the hazard lights. All the ones I see for sale however to not match this button configuration, all having a rotary lighting switch on the left and 2 or more buttons on the right (hazard/seat/lock).
What I'd like to know is, if I bought a 'new' working one, could I just plug the wiring cable from my old one into the new one or, because the buttons are different would I possibly find that they weren't now wired correctly and none would work? Assuming also of course that the male plug matches the female in the replacement clock unit.
Old Feb 25, 2011 | 06:26 AM
speedyxjs's Avatar
It should just plug straight in
Old Feb 25, 2011 | 06:35 AM
biffta's Avatar
Thanks for that. Appreciated.
Old Feb 25, 2011 | 07:26 AM
aholbro1's Avatar
Rotary buttons? On clock module? Never seen it. I thought there were only two versions: with and without seat heaters. What you have should have "Lock" button on the left and "Hazard" on the right? The other has a button with a seat icon between each of those and the clock display, corresponding to left and right seat heaters.
Old Feb 25, 2011 | 08:12 AM
biffta's Avatar
All the ones I have seen for sale have a rotary lighting control on the left of the clock. Here are two examples:-
http://tinyurl.com/62ncg36
http://tinyurl.com/66q8we8
Agree with you about about the sole 'Lock' button on the left, but only mine seems to have it!
Old Feb 25, 2011 | 08:13 AM
Doug's Avatar
The rotary knob is for the headlamp leveling motors...on cars so equipped.
Old Feb 25, 2011 | 12:25 PM
TopHatChef's Avatar
The 'rotary buttons' are on UK models (and probably other Euro models) to level the headlights when the car has more weight in it than normal. We didn't get them in the US.
If you want a clock module without the rotary bits, shop a different ebay.
Try ebay.com as opposed to ebay.co.uk
Old Feb 26, 2011 | 02:42 AM
biffta's Avatar
Thanks Steven, have been looking 'Worldwide' as I suspected my button configuration was US only. If I replace it with a unit which has other buttons including the lock & hazard function, then as long as those 2 work and the cable fits ok then I won't really be bothered.
Thanks again.
Old Feb 26, 2011 | 03:03 AM
biffta's Avatar
When I was thinking about the clock problems which affect so many units, I thought wouldn't it be great if I could find a 12v digital clock display the same size as that in the Jag, remove the faulty one from within the casing, replace it with the new one and connect it to the 12v supply.
Digital clock displays are available all over the place and many are really cheap. There must be one somewhere the same size as the Jag's but so far I haven't been able to find one! If/when I do I think it will be a great option for those many owners with duff clocks.
The only drawback would be the absence of buttons to control time settings, but once the time is set, they don't often go that wrong.
Just an idea.
What do others think?
Old Feb 26, 2011 | 08:47 AM
TopHatChef's Avatar
I think that's a great idea, the only issue would be being in the US and having daylight savings time.
Old Feb 26, 2011 | 09:02 AM
Gus's Avatar
Gus
If repair is an option try this link http://www.modulemaster.com/en/index.php
Old Feb 26, 2011 | 09:42 AM
biffta's Avatar
That would be a drawback I must confess. Back to the drawing board then!
Trying to connect up the time adjust buttons would I think be a bit of a daunting if not impossible task.
Old Feb 26, 2011 | 10:24 AM
aholbro1's Avatar
What target-cost did you have in mind for this fitment? Module-master fix is roughly $120 by the time you ship it both ways. Seems like it would need to be < $60 to depart from stock and put up with adjustment buttons not working, et al...but that's just a guess. Er...somewhere in that range or below would be where I would've considered something else before packing my module off to module masters.
Old Feb 27, 2011 | 03:24 AM
biffta's Avatar
Must say I haven't really researched the idea to any great extent.
LCD clock displays are very cheap (< > 5 dollars) and I thought if someone could find a replacement for the Jag display at a low cost, then it wouldn't be such a huge task for someone with electronic expertise to replace the faulty display with a new one.
I know there are people out there who offer repairs to these clocks for quite a reasonable fee but this involves retaining the current display and repairing the contacts to that display which seem to be the cause of their failure. Long-term reliability would still be a problem I think and if a solution involving replacement of the display itself could be found then to my mind that would be a better route to take.
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
KarimPA
Sep 3, 2015 07:32 PM
