Replacing a module
Old Jan 10, 2021 | 07:07 PM
Sprite's Avatar
Default Replacing a module
When one is replacing a module in their precious is it advantages to unhook the battery to avoid voltage spikes. Especially if that module spent 29 days in USPS limbo from Maryland to Massachusetts! I could have walked it quicker!
Old Jan 10, 2021 | 07:25 PM
Don B's Avatar
Yes, it is always prudent to disconnect the battery before disconnecting an old module and connecting a new one. Many modules are connected directly to battery power even when the ignition is off.
Cheers,
Don
Old Jan 10, 2021 | 09:38 PM
Sprite's Avatar
Thank you. I have done my own work for over 50 years. I have owned many cars. I've had a moded Bug Eye for over forty, but I've never had anything as complex as this jaguar x300. A completely new learning curve. I swear that when I get everything working and the electrical system figured out I will have earned myself a degree in automotive electrical engineering. Unfortunately I no longer have a shop to work in. I will just have to muddle thru. Thanks again.
Old Jan 11, 2021 | 11:09 AM
jmstunts's Avatar
what module are you replacing?
Old Jan 11, 2021 | 02:35 PM
Sprite's Avatar
Mirror seat memory module
Old Jan 12, 2021 | 02:42 AM
..... I've never had anything as complex as this jaguar x300. ......
They get even more complicated going forwards. A laptop is more use than a wrench in many instances.
schuess100
Oct 19, 2022 04:37 AM
Terrance39
May 29, 2020 11:05 PM
Roc3207
Sep 11, 2017 05:17 PM
Del Boy
Apr 19, 2014 06:21 PM
arthurdaley
Jan 3, 2013 11:04 AM
