stalls when comes to a stop
Hi! Had the same problem on my 3.2 xj6 for three years. Stall issue wasn't regular but happened only on warm engine. I've changed spark plugs, ignition coils, fuel filter, washed injectors, changed CPS, washed the throttle, cleaned ground points, changed the ECU, fully repaired transmission, changed diff..
The problem appeared from time to time untill I replaced rear ABS sensor, which is also a speedometer sending unit... No trouble codes or something like that appeared, speedo stopped working sometimes, but i'll never think that it could cause such troubles!
Jag mechanics with great work expirience in Moscow coudln't find this issue using official diagnostics unit. If you have a spare ABS sensor - try to change it? Our old-styled ABS with long wire are too expensive, so i just bought used rear x308 hub carriers with abs-sensor and wire and now feel safe from expensive repair in future..
There are a lot of stall issue threads on this forum and in every case trouble is different. Hope you'll fix it!
Bad tank of gas , happens
The X300 tank can be siphoned , at least on mine
Fuel injector cleaner in the tank , Chevron gets good marks
The fuel injector pulse width is at it's shortest at idle , if you had dragging injectors this is where it shows up
Binding Inlet air control valve , this has some mounting hardware that can snap off
Someone recently found the EGR valve " coked " over and was able to get some results from cleaning
The transmission connector on the transmission body left side , this is a " Deutsch " connector and has a unconventional way to remove it
This gives trouble around the 1st gear range from park as the tranission and engine ECU must coordinate with each other
Time for a good grounds cleaning including the large woven strap on the starter motor mounting bolt , best gotton to from the under the car
