Strange air pipe
Old Aug 13, 2013 | 09:04 AM
Satterfield's Avatar
Default Strange air pipe
Can anyone tell me what the little air hose is for coming out of the bottom of the air intake box, Thank you for reading, Satterfield
Old Aug 13, 2013 | 04:08 PM
FireCrow's Avatar
I've modified mine, so can't have a look at it and tell you, but if you have picture of it, would be handy!
Old Aug 13, 2013 | 05:27 PM
Thanks for the pictures , I am looking at MOD also, I am just wondering ,what if anything I will gain from changing it, so we will see, Satterfield
Old Aug 13, 2013 | 05:51 PM
Took a while to find a picture of the bottom of the filter housing:
If it's the stubby outlet arrowed in red, it's at the lowest point of the housing and is presumably there as a drain.....?
Old Aug 14, 2013 | 02:03 AM
FireCrow's Avatar
Strange that, mine had that one blocked off, from factory! I remember, because I was wondering why on earth would they put there in first place, if they blocked it off anyway...
Old Aug 14, 2013 | 08:09 AM
SleekJag12's Avatar
My friends, that is the fitting for the air injection pump! Folks in the UK probably have it capped off as you do, Firecrow, I don't believe you need an air pump in the UK! The pump pulls air from the filter box and stuffs it down the exhaust manifolds, to burn off excess fuel and heat up the O2 sensors after a cold start. Definitely a USA spec emissions item.
I don't care for it myself! The ECU cycles it frequently even when the engine is warmed up, causing a strong current pull (it is electric) and a short glitch in the fueling, sometimes almost causing a stall at idle. I leave mine disconnected and can go many weeks before the ECU reminds me of it. Don't tell the EPA!
Old Aug 14, 2013 | 10:27 AM
FireCrow's Avatar
EPA! EPA! EPA!
sorry, I couldn't resist it
Old Aug 14, 2013 | 10:41 AM
Originally Posted by SleekJag12
My friends, that is the fitting for the air injection pump!.........
Thanks for the explanation.
Makes sense that it's pulling filtered air as a feed to 'something' (the air pump) that we don't have ........ yet!
Old Aug 14, 2013 | 08:30 PM
aholbro1's Avatar
with the hose:
as stated, the other end goes to the air pump:
Attached Thumbnails Strange air pipe-img_20130814_194845_zps190fb624.jpg   Strange air pipe-img_20130814_194855_zpsbc311f43.jpg
xjrjag
Oct 24, 2024 03:09 PM
1100me
Jul 24, 2023 06:10 PM
Wahooesprit
Dec 23, 2019 02:01 PM
simo5555
Sep 9, 2015 06:22 AM
1100me
Sep 7, 2015 06:26 AM
