Strange Stereo Fault
Old Jun 11, 2023 | 10:26 AM
Rothjag65's Avatar
Default Strange Stereo Fault
I`ve got a `95 X300 with the 6 disc CD changer in the boot,got in the car today and none of the head controls would work,the cassette still plays,and the CD still plays,but I can`t do anything from the head unit,not even changing the volume,or even turning it off.
It`s been fine before,is there a fuse or something for the head unit,or is it something else ?
Old Jun 11, 2023 | 03:02 PM
Parker 7's Avatar
The on / off volume knob is a encoder device that can be changed
They come in different shaft sizes
The following pic is a example but not the exact size needed
Old Jun 12, 2023 | 01:03 AM
Parker 7's Avatar
See post # 8 as the Alpine / Jaguar AJ9500 stereo head is taken apart
aj9500 encoder jaguar forums
Old Jun 12, 2023 | 02:30 AM
SleekJag12's Avatar
It is a full-on internal repair to replace that knob. Every AJ9500 radio has had or will have that problem. Surprised to hear one was still working until now!
One solution is to wait a day or two. The head unit will start working properly again, when it is ready.
Old Jun 12, 2023 | 03:10 AM
Rothjag65's Avatar
Thanks,did a search for that,but couldn`t find anything.
Old Jun 12, 2023 | 02:30 PM
Parker 7's Avatar
Since you have the premium system you have the trunk mounted final amplifier
Place your hand on it after a while that is gets warm indicating it is turned on and a fuse in the trunk
The other 2 fuses are in the left heelboard fuse box I believe
There have been problems with the round 8 wire cable from the head to the trunk components as the cable gets pinched , but that is a dig to get to
The encoders come in the same pinout configuration but different shaft sizes so is a catalogue search through
once one is found recommend liquid soldier and a heat gun to resoldier
Old Jun 12, 2023 | 02:36 PM
Parker 7's Avatar
Encoders | Electronic Components Distributor DigiKey
Old Jun 13, 2023 | 03:37 AM
countyjag's Avatar
When my premium system cut out, I noticed the aerial also retracted, although there was still power at the head unit, just no sound. The part of the head unit which controlled power to the amp ( separate from the encoder) was at fault. I gave the amp an accessories fed power supply, and all is well, with the only side effect being the amp is always on when the key is on, which it would be 99% of the time anyway.
Old Jun 13, 2023 | 05:49 AM
Rothjag65's Avatar
Update.....had a look this morning and it`s fine !
All controls working as normal,if it goes again I managed to locate someone on Ebay in the UK selling the part that is needed.....hopefully !
Old Jun 13, 2023 | 01:05 PM
Parker 7's Avatar
What was the part # for the encoder as I was never able to nail down when I looked
Jackson_Dkmg
Nov 13, 2020 09:34 AM
Ron62
Aug 28, 2017 12:23 AM
jol
Feb 22, 2012 08:18 PM
charm11
Jul 22, 2010 03:31 PM
The_Sauce
Oct 2, 2009 01:52 AM
