Sun roof lubrication
Old Jun 8, 2024 | 04:14 PM
PBoudr's Avatar
Default Sun roof lubrication
I actually drove around for a bit with the sun roof open. It opened and closed smoothly but when I got home I noticed the rails were a little sticky with old grease I presume. I'm thinking about cleaning them up and adding some new lube. Any suggestions on what to use. I have white silicone grease but I'm not sure if that's the best choice. Anyone think something else might be more appropriate? Thanks.
Old Jun 8, 2024 | 05:01 PM
Parker 7's Avatar
Lots of TSBs on the sunroof
Some Youtube videos
See section 13
JagRepair.com - Jaguar Repair Information Resource
The same sunroof on the X308 ( V - 8 ) model
Old Jun 9, 2024 | 01:56 AM
watto700's Avatar
G'day P,
I have used motorcycle chain spray lube on my sunroof mechanism and it gets in everywhere and works just fine.
Cheers,
Jeff.
Old Jun 9, 2024 | 05:43 AM
PBoudr's Avatar
Originally Posted by watto700
G'day P,
Cheers,
Jeff.
Thanks, when the rain stops I'll give it a try. A little preventative maintenance goes a long way.
Old Jun 9, 2024 | 06:17 AM
watto700's Avatar
G’day P,
You can buy the chain lube in cans with a thin plastic tube as part of the nozzle which allows you to lube all the hard to get to bits. There is quite a lot of solvent in the oil when you spray it which eventually evaporates leaving the oil behind on all the components.
Cheers,
Jeff.
Old Jun 9, 2024 | 05:43 PM
motorcarman's Avatar
Jaguar issued TSBs for the sliding roof lubrication.
Jaguar recommends Molykote 111.
Ron1
Nov 11, 2021 10:28 AM
SonofGaladriel
Dec 29, 2019 09:09 PM
Gus
May 26, 2016 05:22 PM
malc4d
Dec 11, 2014 08:45 PM
Simprof
Jul 5, 2011 03:31 PM
