Thermostats
Old Apr 18, 2014 | 01:29 PM
Bucky83's Avatar
Default Thermostats
Anyone using the 174 degree thermostats? I'm replacing mine this weekend and was going to opt for the lower temp if it doesn't cause any issues.
Old Apr 18, 2014 | 02:22 PM
Brutal's Avatar
i wouldnt do it. if anything that car needs a hotter t stat since the heaters suck. and youre in Pa
Old Apr 18, 2014 | 02:44 PM
Don B's Avatar
Hi Bucky83,
Your fuel mileage might possibly suffer since the engine might not reach its optimum operating temperature under typical driving conditions, and arguably the lower temps could lead to accelerated wear of the engine's internals.
What is prompting you to consider the lower temp? Below is a link to an article that seems to dispell some of the myths about using a 'stat with a lower-than-recommended opening temperature:
Low Temp Thermostats: What’s the Advantage? | Tuner University
Cheers,
Don
Old Apr 18, 2014 | 03:29 PM
Mikey's Avatar
Excellent post, thanks. One more myth that just won't die.
Old Apr 18, 2014 | 03:48 PM
plums's Avatar
... is an author, entrepreneur and automotive enthusiast with over 10 years of experience building and modifying cars ...
He's still a pup and the site is basically a shill site for his "courses". That's the entrepreneur part.
Old Apr 18, 2014 | 04:07 PM
Don B's Avatar
Here's a link to a MotorWeek video that mentions that a thermostat that is running too cool can adversely affect fuel economy. I have experienced this twice with our '93, when fuel economy declined noticeably (2-3 mpg) and the cause was a stuck-open thermostat.
10 Fuel Saving Tips You Can Do Now | MotorWeek
A new, working lower-temp 'stat will have a lesser impact, but over time the cost of lower fuel economy will add up since the ECM will enrich the air-fuel ratio to compensate for the cooler engine operating temps.
Bucky83, ambient temps in Pennsylvania aren't known for being especially hot - what's your reason for considering a lower-temp 'stat?
Don
Old Apr 18, 2014 | 04:37 PM
Bucky83's Avatar
Hi all, no real reason, i just thought it wouldnt have real adverse effects. I will stay with stock temp. Should I land on a specific brand or will any "front line" brand be acceptable? FYI it is stuck open, not overheating or anything.
Old Apr 18, 2014 | 07:15 PM
Bucky83's Avatar
Went with the Beck Arnley @ OEM spec.
Old Apr 18, 2014 | 08:29 PM
Don B's Avatar
Your engine should be happy! :-)
Old Apr 19, 2014 | 09:38 PM
Bucky83's Avatar
She is VERY happy! My son and I removed the throttle body too... Boy, what a mess! Had some minor issues but she's running fine (probably better than she has for years). There was about 1\16 -1\8 of an inch of buildup on one side and approximately 1\16 on the other side of the butterfly. It is spotless now. Tomorrow will be an Easter afternoon claybar/ wax session. :-)
Old Apr 19, 2014 | 09:42 PM
Don B's Avatar
Well done Bucky, not only for completing the thermostat swap and throttle body cleanup, but also for helping to train the next generation of Jaguar owner-mechanics!
Cheers,
Don
Old Apr 19, 2014 | 09:57 PM
Bucky83's Avatar
Cheers,
Don
Thanks for the kudos. He's a good kid that is beginning to appreciate the value and satisfaction of working on our vehicles. One of the IACV screws did the dreaded snap but we drilled it out, extracted it and re-chased the threads with good final results.
He did note that I am calmer when I work on the Jag. :-)
Old Apr 19, 2014 | 10:01 PM
Bucky83's Avatar
One final note for anyone considering the Beck Arnley product: They are VERY well made and they come with the seal... Well worth the extra money.
Old Apr 20, 2014 | 12:35 PM
cool's Avatar
Hi Bucky83,
Cheers,
Myth: running engine at lower temp will cause accelerated / premature wear. Its engine oil that keeps the moving parts lubricated (internal mechanical parts of an engine, crank shaft, bearings, piston arms, piston bearing etc)
I frequently read about this cause and effect of operating temperature and what can happen, as an automotive engineer both are right and wrong, first it does not necessarily mean a cooler engine will wear down the engine prematurely (absolutely not true) your engine will suffer premature wear if you do not periodically change engine oil and oil filter. The only thing that can go wrong when you run on cold engine is you will not get a smooth run but as soon as the car idles for a few minutes or after a short period of slow drive (within 30 MPH) the temperature will always reach its optimum. a cooler (a little bit below) working temp is always good, going a bit higher than normal working temp is always bad.
Understanding the specifics and technical properties of the engine parts and functions can eliminate some wrong old school notion. I was in the same position before i went in depth into the subject matter.
Don
Old Apr 20, 2014 | 02:18 PM
Mikey's Avatar
Why is it good?
hoodun
Feb 20, 2023 05:52 AM
mikiep
Dec 20, 2019 07:37 PM
Lubrication
Oct 1, 2015 03:56 AM
zoozth
Sep 29, 2015 07:28 AM
hoodun
Sep 28, 2015 08:32 PM
