tick over
Old Jun 29, 2014 | 02:26 PM
deecee.3595's Avatar
Default tick over
hello all ,great to be back ,have small problem ,1997 x300 3.2 auto tick over a little high 1000 or just over at times ,can you point me to a solution ,or what the problem may be 115000 mls been stood quite a while ,will get MOT tomorrow all work done ,just this tick over ,AND gear selector solanoid is this a common thing and which is best way to solve ,hope you can help ,i am certain you can ,all the best ,deecee,
Old Jul 1, 2014 | 05:26 PM
Welcome to the forum deecee.3595,
I've moved your question from UK Region to X300 forum. Members here with the same model will be able to help.
Old Jul 1, 2014 | 05:38 PM
Don B's Avatar
Hi deecee,
Welcome to the forum! Use the forum search function to search for Idle Air Control Valve, which is supposed to regulate the idle speed under control of the Engine Control Module (ECM), but with age it tends to accumulate gunk and sieze.
Vacuum leaks or intake air leaks after the Mass Air Flow Sensor (MAFS) are other common contributors to fast or rough idle.
I'm sure other members will offer other ideas, but there's plenty of information available already if you'll use the search window at the top of the page.
Cheers,
Don
philwarner
44
Nov 5, 2024 06:29 PM
jospolice
Oct 2, 2015 07:16 PM
willemh
Sep 28, 2015 06:22 AM
Cash Jackson
Sep 26, 2015 07:33 AM
