Transmission fail light
Old Jun 28, 2014 | 12:29 PM
Arch's Avatar
Default Transmission fail light
97 XJ6 transmission fail light came on with two codes. B30F4,B13BO. They are not in automatic transmission section of the manual nor anywhere else I can find. I can put the light out but it comes back on. Any ideas? Arch
Old Jun 28, 2014 | 02:22 PM
Don B's Avatar
Hi Arch,
I dont find those codes either - one of the more complete X300 code lists I know of is here:
Generic and Jaguar specific OBD-II Diagnostic Trouble Codes
Since your fault codes are so odd, they may represent some sort of implausible signal received by the ECM or/and TCM. It might be worth cleaning the grounds used by the ECM (ground studs on the bulkhead and front left fender, I think) and TCM (a stud on the center console).
When your transmission warning lamp illuminates, does the transmission lock in 3rd gear (Limp Home Mode)? If so, a common cause of LHM is contamination of the Throttle Position Sensor (TPS) or its electrical connector.
Cheers,
Don
Old Jun 28, 2014 | 02:27 PM
annamiata's Avatar
Just codes? Any actual transmission problem? If you have not changed the transmission oil and filter, I guess now is the time to do it.
Old Jun 28, 2014 | 05:30 PM
b1mcp's Avatar
What are you using to read the Trans codes?
Invalid / gibberish codes can result from using a generic code reader that doesn't fully understand the protocol / interface to the module.
Old Jun 29, 2014 | 10:33 AM
Arch's Avatar
Thanks for the input. I'll clean the grounds. I used the OBD-II scan tool to clear the transmission fail light. Check Engine light never came on. Fluid and filter was changed 3000 miles ago, the pan was clean. There's no leaks, shifts good and doesn't go into Limp Home Mode. Thx Arch
Old Jun 29, 2014 | 11:49 AM
motorcarman's Avatar
You probably need a proper WDS or PDU (maybe IDS or AutoEnginuity??) to read the codes in the TCM.
Once you know the correct JAGUAR DTCs you can begin the diagnosis.
bob gauff
Jpav27
Jul 31, 2022 06:43 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
rachelstr
Sep 3, 2015 12:59 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
