Trunk doesn’t open
Old Jul 22, 2025 | 09:35 AM
nakuttaja's Avatar
Default Trunk doesn’t open
Hi
The electric trunk lock opener stopped suddenly working in my X300. The fuse and relay are checked and working. Neither the switch inside nor outside opens the lock. The lock opens with the mechanical key only. So, some electrical problem somewhere, I assume. Does anyone have a hint, where to start looking or how to repair?
Thanks already in advance.
Old Jul 22, 2025 | 10:07 AM
Ya Tigor's Avatar
I would try to directly feed the actuator from the battery to check if it works.
Old Jul 22, 2025 | 10:26 AM
motorcarman's Avatar
Electrical guides come in 'handy'.
The diagrams are meant for exactly this.
JagRepair.com - Jaguar Repair Information Resource
Old Jul 22, 2025 | 10:39 AM
944play's Avatar
I would look at the harness in the trunk hinge. Likely a wire has fatigued in the flexure. The actuator lives in the trunklid.
Old Jul 23, 2025 | 06:30 AM
nakuttaja's Avatar
Thanks for everyone for the support.
Old Jul 24, 2025 | 10:08 AM
Parker 7's Avatar
There was something about the linkage wearing between the actuator and the latch
There was some good pics in some post
This assuming the actuator does work and the wires under the curved plastic cover on the car's right trunk hinge not worn / damaged ( common from reading )
Your wire colors are X and Y
Someone made a video
Old Jul 24, 2025 | 10:23 AM
nakuttaja's Avatar
Thanks again for everyone. I could fix it today. The problem was the earth connection of the actuator. I put a new wire from the actuator to the ground, and it fixed the problem.
FredA101
Mar 18, 2022 04:11 PM
losfinch
Dec 3, 2021 07:26 AM
VancouverXJ6
Jun 21, 2020 01:57 PM
95Leaper
Aug 30, 2016 05:35 PM
Alex B
Jan 7, 2012 06:25 AM
