View Poll Results: What tyre pressure do you use for maximum comfort?
26lbs front/28lbs rear
20.83%
30lbs front/32lbs rear
16.67%
32lbs front/32lbs rear
58.33%
Tyre pressure, what's that?
4.17%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Tyre Pressure for Maximum Comfort
Old Mar 30, 2011 | 04:06 PM
bob5tafford's Avatar
Default Tyre Pressure for Maximum Comfort
I'm new to this forum and to owning Jags, But I was wondering how many members/owners follow the sticker that is in the console for tyre pressures for maximum comfort? 26lbs for the front and 28lbs for the rear seems a little low for me. But I do have to admit, it is a very comfortable ride (in my '97 x300)! I'm also concerned about wear on these tires also. What does everyone think?
Old Mar 30, 2011 | 05:23 PM
Doug's Avatar
I find "comfort" in having the tires at a higher pressure where they'll be less likely to overheat and fail :-)
32/32 for me
Old Mar 30, 2011 | 06:35 PM
TopHatChef's Avatar
I'm with Doug on this one.
Old Mar 30, 2011 | 06:36 PM
Oubadah's Avatar
EDIT never mind.
Old Mar 31, 2011 | 09:08 AM
madfred's Avatar
30/32 for me but on 245/18/45 low profiles
Old Mar 31, 2011 | 11:02 AM
locogringo's Avatar
My personal rule of thumb is the lower the profile the higher the pressure. helps prevent damage to the sidewall and catastrophic failure. Who needs a tire blowout on the highway at 75 mph?
Old Mar 31, 2011 | 02:35 PM
Never seen that notice before.
If you are a rear seat type of chap then the comfort setting is what 'James' is likely to go for.
But if you are a steering wheel turner I'd go with 'normal' or maybe a tad higher.
Old Mar 12, 2015 | 06:01 AM
MikeyB10's Avatar
When I first purchased my 95 x300, all four tiers had 28 psi in them. Again after I had it in at the shop once they came back at 29 psi.
Personally I like the feel and handling of my Jag with 34 front and rear.
Old Mar 12, 2015 | 09:29 AM
countyjag's Avatar
I am running 45 profile tyres on my XJR, and despite what the sticker says, I was not convinced that 26/28 was sufficient. I have found 30 all round to be very comfortable, but am currently running 34 all round. Feels great to drive, but interestingly, when I went to 32 as an intermediate step, a few trim vibration noises manifested themselves on rougher road surfaces. What fun I had tracking them down!
Old Mar 12, 2015 | 04:33 PM
Kleman's Avatar
My rule for all the cars I own / owned so far: Manufacturer's recommendation plus a little. Works wonders, but I always have stock tire and rims.
studentper
Feb 20, 2016 09:43 PM
AnD3rew
Sep 26, 2015 06:06 PM
Woznaldo
Sep 26, 2015 11:02 AM
reb1999
Sep 25, 2015 10:00 AM
