Voltage dial goes to nothing
Old Apr 21, 2018 | 10:48 PM
Lady Penelope's Avatar
Might not have refreshed deep enough . Go back to the X300 page , then go to your thread .
Old Apr 21, 2018 | 10:53 PM
cdma's Avatar
you are my new hero. Started the car no blown fuse. Thanks so much for your help...fingers crossed
Old Apr 21, 2018 | 10:54 PM
Don B's Avatar
Originally Posted by cdma
going to take some sandpaper to the connector as they look clean but seem to be a little oxidized. so when i get them clean and put back together and fusses pulled and ac removed do I then go ahead and try again. by the way post 4 looks the same unless i am missing it. sorry to be such a pain.
Please don't use sandpaper on any connections, not even fine grit sandpaper. The scratches allow humid air and moisture to invade the contact surfaces and promote future corrosion. A brass-bristle brush is much better, along with zero-residue electronic cleaner (CRC is a popular brand). You're looking for a gas-tight connection.
Cheers,
Don
Old Apr 21, 2018 | 11:02 PM
My work is done . My mom says I need to get to bed now
Old Apr 21, 2018 | 11:03 PM
cdma's Avatar
Spoke too soon. Put the washer relay in started the car and POP
Old Apr 21, 2018 | 11:04 PM
Then don't do that . Your going through fuses like popcorn ,
Remove the washer relay and as you run the car wringle the black connector below the fill cap
Old Apr 21, 2018 | 11:16 PM
cdma's Avatar
i will give up tonight and try again tomorrow. I removed the washer fuse wiggled the black connector and turned the key and pop
Old Apr 21, 2018 | 11:35 PM
  #28
Old Apr 22, 2018 | 05:17 AM
cdma's Avatar
SO is that what you think it is? Yea I am torn between continuing to try to fix it myself and just dropping the car at the Jag dealership. I think today, since they are not open, I will go through the whole process again. Go by autozone and get a bunch of 5 amp fuses, connector cleaner, and parts for my sons car, that just so happen to crap out, and give it another shot. I am not sure that I am willing to go through replacing the whole connector. Can you send me the link to the supplier and how you would go about replacing them?
Old Apr 22, 2018 | 07:19 AM
  #30
cdma's Avatar
Also I see relay 7&8 I took out number 7 but not sure I have an 8 because when I look in front of the fuse box I only see two relays and not three. Saw three. It was a long night and a VERY crappy day.
Old Apr 22, 2018 | 08:18 AM
  #31
The other relay is for headlight washer pump option .
Old Apr 22, 2018 | 08:26 AM
  #32
cdma's Avatar
GM....Can I get your source for the plugs please? About ready to start again. I will let you know what I find if anything but off to the store to by a case of 5amp fuses
Old Apr 22, 2018 | 08:31 AM
  #33
You can jumper a wire around the connector and bypass the problem ( if it is the connector shorting to ground ) The first one being most important is the one going to the Alternator in position 2 , White Blue wire .
Not being sure that it is the connector , but they do have a common history . The other White blue wire in position 4 is for the windshield washer nozzle heaters ( yep it's got them ) and they may be shorting out to ground on the other side and not related to the connector so you would just cut that wire to isolate the problem .
Old Apr 22, 2018 | 08:39 AM
  #34
cdma's Avatar
How do you remove the wires from the connector. Just push the pin back through?
Old Apr 22, 2018 | 08:58 AM
  #35
I'll have to look for my condition was bad and just cut one connector out and butt spliced the wires . That was before I found the connector source . Git er done mode
Old Apr 22, 2018 | 09:58 AM
  #36
cdma's Avatar
I would think that if i cut those wires and went to turn on the key after I cut it, did not hook them back up, that the fuse would not blow. I am not even starting the car
Old Apr 22, 2018 | 10:04 AM
  #37
You can validate that test that makes sense by watching the fuse blow before start position , Then one cut at a time redo that test
Looking to see if there was a uprating of the fuse size as there were on other items
No there was not on this fuse
Old Apr 22, 2018 | 10:16 AM
  #38
cdma's Avatar
both were cut when i turned the key. first i jumped then it blew. then I disconnected them turned the key and it blew again. I have all the other fuses disconnected as you said.
Old Apr 22, 2018 | 10:17 AM
  #39
You'll have to buy the female side also , this source is from England
https://www.3waycomponents.co.uk/13-...-Connector-Kit
Old Apr 22, 2018 | 10:26 AM
  #40
At the very bottom of the fuse box itself there is a connector attached to the box . Remove and isolated the fuse box terminal post as it's hot from the battery then remove the fwd and aft box securing bolts to flip over .
We'll have to go back over if and how evidence points to the 10 wire Papa Indy 61 connector
