Windshield washer reservoir
Old Feb 9, 2014 | 10:49 AM
BobGalvin's Avatar
Default Windshield washer reservoir
Hi;
My name is Bob Galvin from Olive Branch, MS and I am a new member.
Looking for some help in replacing the windshield washer reservoir in my 1996 XJ6. Not sure if that's the total problem for the leak but seems to be the most obvious at the moment. Any help would be appreciated
Thanks,
Bob Galvin
Old Feb 9, 2014 | 01:45 PM
Bob,
I've moved your question from XJ ( X305 ) XJ12 to X300 forum.
Members here with the same model will be able to help.
Old Feb 9, 2014 | 01:54 PM
aholbro1's Avatar
Welcome to the forum, Bob. Glad you've joined us!
As you probably know, it lives in the lower right front corner. There are a few threads on here; Some have fitted a plastic bottle and others have found a reservoir from another car is a good fit. Can't recall but I believe it was some sort of Chrysler. All this due to the expense/lack of availability of the original. I'll try to find them and edit back some links. If you have the replacement in-hand, you should be able to find the procedure in the stickies, I believe the manual is available for download there - but you may need to boost your post-count to 10 for upgrade to full-status in order to access it.
Quick search returned the following:
https://www.jaguarforums.com/forum/x...sensor-107761/
https://www.jaguarforums.com/forum/x...system-103172/
https://www.jaguarforums.com/forum/x...acement-89314/
https://www.jaguarforums.com/forum/x...ight=reservoir
https://www.jaguarforums.com/forum/x...g-light-81901/
https://www.jaguarforums.com/forum/x...servoir-58044/
https://www.jaguarforums.com/forum/x...er-tank-54214/
https://www.jaguarforums.com/forum/x...servior-48056/
https://www.jaguarforums.com/forum/x...er-help-46858/
https://www.jaguarforums.com/forum/x...en-plas-37559/
There are probably more .....
Old Feb 9, 2014 | 08:58 PM
steven300's Avatar
i used a washer fluid bottle off a 93-97 dodge intrepid.close fit but not as tall as original...steve.
Old Dec 5, 2018 | 03:03 AM
Canuck XJR6's Avatar
Hey Bob,
Did you ever sort out the windshield reservoir on the XJ6? I also need to replace mine and was wondering if you found a suitable replacement from another car perhaps? I’m now in Canada and that item is needed to pass inspection.
Old Dec 5, 2018 | 11:54 AM
cdma's Avatar
Is the bottom damages to the point where it can't be patched. I have used the JB weld, Water Weld, on mine, and it was a big hole, and has been good for over a year
Old Dec 6, 2018 | 10:42 AM
gr8punkin's Avatar
I used an old T shirt and epoxy to fix mine. It's been good for over year.
Cleaned the reservoir, scuffed up around the edges of the hole. Drilled any spider cracks. Cut T shirt material to be 3/4" - 1" larger than necessary. Soaked it in 5 minute epoxy and then laid it over the hole. After the epoxy was set up I mixed up one more batch of epoxy to add some thickness and go over the edges of my patch.
Old Dec 6, 2018 | 01:32 PM
Lady Penelope's Avatar
Fits perfect
Old Dec 7, 2018 | 12:52 PM
At first I thought I was being sold protein powder lol!!!
Thanks for a great tip!
Chris
Old Dec 7, 2018 | 03:22 PM
See Hanz and Franz at the gym for an empty jar
Poet
Feb 7, 2025 02:18 PM
X308XJR
May 20, 2019 06:50 PM
King Charles
Oct 16, 2015 01:25 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
