Won't start
Old Apr 25, 2022 | 07:00 PM
Warrenbrown55's Avatar
Default Won't start
I have a 96 xj6 vanden plas was at the gas station when the car started having trouble started spurting and running rough but made it the half mile home when it shut down completely side note before this no problem whatsoever. I changed the feul pump feul pump relay and feul filter and car still won't start any ideas
Old Apr 25, 2022 | 09:44 PM
Vee's Avatar
Vee
How many miles on the car? Could the fuel pump be dying?
Old Apr 25, 2022 | 10:42 PM
Default Won't start
148k I changed feul pump fuel filter fuel pump relay
Old Apr 26, 2022 | 06:47 AM
Vee's Avatar
Vee
I think you'll have to do a check for (1) fuel at the injectors and (2) spark at the plugs.
Old Apr 26, 2022 | 10:49 AM
no feul at rail
Old Apr 26, 2022 | 03:10 PM
Vee's Avatar
Vee
Something may have happened to the fuel pump.
May as well check the easy part first....is the inertia switch at the passengers door hinge triggered? That cuts fuel off in the event of an accident.
Also, the fuel pressure regulator? After that I start looking at the ECU? Any corroded pins?
Old Apr 26, 2022 | 04:07 PM
no accident but will check switch
Old Apr 27, 2022 | 04:35 AM
countyjag's Avatar
From memory rather than experience, can the feed pipe not sometimes detach in the tank?
Old Apr 27, 2022 | 05:53 PM
Default Fixed
it ended up being a 5 amp fuse that control the fuel pump relay
Old Apr 28, 2022 | 02:10 PM
Vee's Avatar
Vee
Thank you for coming back to share the conclusion. Hate it when people never come back.
Old Apr 28, 2022 | 03:07 PM
Nobeel Masri's Avatar
Great that you found the cause.
I was wondering how the car got you the half mile home with a failed fuel pump fuse.
Maybe there's still some magic in there somewhere.
Old Apr 28, 2022 | 03:13 PM
I'm thinking I popped the fuse sometime during installation but drove it an hour to work this morning driving really well as smoothly as my s500 mercedes
Warrenbrown55
Apr 25, 2022 07:00 PM
hambone6253
Aug 10, 2018 04:26 PM
paultson
Aug 21, 2017 10:27 PM
paultson
Aug 21, 2017 08:09 PM
holybananas
Aug 5, 2009 03:24 PM
