XJ6 will not start
Old May 8, 2019 | 08:00 PM
Gaston Robert's Avatar
Default XJ6 will not start
Car has been sitting couple of years in a nice dry garage .
i replaced the battery . Now the car will not ;
start .dash all lights up .
shifter will not come out of park .
door locks will not work.
any ideas?
______________
1995 XJ6 (added by GGG)
Old May 8, 2019 | 08:58 PM
Robert,
Welcome to the Forums. When the Jag is sorted, please do an Intro in the New Members are.
A tad vague about your car???
Jaguar used XJ6 naming from 1968 to well into late 2000nds. Very different beasts from the start to the finish, and obviously very different sets of problems.
Let us know the Year, etc of your Jag XJ6, then members with the same vehicle can assist without guessing.
Old May 8, 2019 | 10:43 PM
Default Gaston
1995 year thanks
Old May 8, 2019 | 10:57 PM
OK, thanks.
Your car is known in Jaguar talk as an X300.
That Tech Section is down the home page a tad.
Both mine did that when battery disconnect took place, and a simple "lock and unlock" of the car once the battery waa connected sorted them both. Also worked with both the S Types. Not sure on the X Type yet, never touched the battery.
Old May 9, 2019 | 03:28 AM
Originally Posted by Gaston Robert
..... any ideas?
Welcome to the forums Gaston Robert,
I've moved your question from General Tech Help to X300 forum. This is the place to post questions about your 1995 XJ6.
Old May 10, 2019 | 03:28 AM
SleekJag12's Avatar
"Will not start" is unclear. We need to know if the engine cranks but does not fire up, or if the engine does not crank. Two different problems.
Foot must be on brake to pull the shifter out of Park (ignition ON only). If the brake switch has failed, the shift lock won't release. Your brake lights will not work either, so that's easy to check.
The red "P" indicator on the shifter must be lit for the engine to crank (but it still might not fire up and run).
Old May 10, 2019 | 02:43 PM
Parker's Avatar
Some questions to define your issue towards solution
Which country . as there is a security inhibit in some markets ?
Does the starter relay click with your finger on it ?
Do you have starter rotation ?
Does the voltage sag on the instrument gauge drop under 11.4 volts during starter rotation ?
Does the fuel pump relay click with your finger on it ? you will feel 3 clicks if good in the start sequence as it relates to the fuel pump relay on / off / on
Do you have old / stale fuel in the tank ?
Old May 11, 2019 | 01:50 AM
Parker's Avatar
see page 17 and 19 for relay location in the file below :
You have to put your finger on the relays and not just listen for them as others close by in starting sequence
http://www.mediafire.com/file/45wwgj...0+1996+LWB.pdf
There is an issue with stored X300's with cylinder / rings bore not sealing for enough compression for a light off
2 easy fixes
Old Dec 29, 2019 | 03:13 AM
myk1e's Avatar
Default myk1e
I have read a lot, am about to have a go
Many thanks
stupid
Jul 3, 2019 06:37 PM
Sonas
Apr 27, 2019 12:13 PM
Jagall73
Apr 20, 2019 10:22 AM
Timeisrelative
Apr 16, 2019 09:09 PM
bshambaugh
Apr 11, 2019 05:07 PM
