XJR6 Transmission Output Shaft Seal Question
Old Mar 12, 2018 | 01:44 PM
FrozenApple's Avatar
Default XJR6 Transmission Output Shaft Seal Question
Hello everyone,
It's been awhile since i posted on the forum, but i do still check it on regular basis. It's almost that time of the year where I insure the lovely jag and of course fix a few things that needs addressing. Now.. I noticed there was a leak coming from the output shaft seal, so this would be the first thing i'm tackling this year! I know there's a guide here now.. just curious does the xj6 and the xjr uses same part? and this guide would apply to the xjr as well?
http://www.jagrepair.com/images/Auto...eals%20R&R.pdf
Jacky
Old Mar 12, 2018 | 03:36 PM
JBzXJ40's Avatar
They use different transmissions.
The XJ6 N/A either had 4HP22 or 4HP24. The XJR6 used the 4L80E from GM. You can still order the parts from Jaguar - but most likely you can get them from a GM dealer for less money.
Old Mar 12, 2018 | 05:41 PM
Jagboi64's Avatar
The rear mount and output housing is completely different between the ZF and GM transmissions.
$3.23 Canadian at Rockauto.com: https://www.rockauto.com/en/moreinfo...302703&jsn=682
Old Mar 12, 2018 | 06:40 PM
Excellent news! obviously that guide is no use to me, any other gaskets? or washers? that needs to be replaced ?
Old Mar 13, 2018 | 12:12 AM
Jagboi64's Avatar
I don't think so. I've not done it, but I had a look at my transmission (it's out of the car) and it looks fairly straightforward. Famous last words!
It's a GM 4L80E, so you can search chevy forums to see if there is anything useful there. The rear flange is different from a GM application, as Jaguar used a bolted flange to connect the driveshaft, GM used a splined yoke.
eurolat
Feb 12, 2018 03:35 AM
o1xjr
Apr 16, 2014 10:09 AM
penguin
Jan 26, 2012 09:10 PM
pdog2000
Jun 8, 2011 12:26 AM
cancer63
Feb 26, 2010 12:19 AM
