02 jag xj8 jack stand points
Old Jun 19, 2020 | 02:17 PM
  #501
Mrjay622's Avatar
A quick search, fuel line / AC Quick disconnect tool.
Just gald you got it off. What a savings ...
I know on my car the pump and fuel filter was replaced by a dealer for over 1400$ or 1133.17 GBP and that was 6 years ago....
let me know when your On your way I'll put up a spot of tea.....
Old Jun 19, 2020 | 02:22 PM
  #502
Highhorse's Avatar
Your in great position dangelous, ...its not totally easy from here, but the bear was getting those lines out and the others uncoupled. You'll have to work back and forth, a little at a time at first, the tank to get it out...that's where the friend comes in handy. The tank itself is quite lite for its size, its the fuel inside that makes it cumbersome.
Old Jun 19, 2020 | 02:23 PM
  #503
dangelous's Avatar
Hahahahaha outstanding! Make sure it’s Yorkshire tea!
Old Jun 19, 2020 | 02:26 PM
  #504
dangelous's Avatar
Thanks HH I had the tank half out before the rain so not overly worried about that! It’s the cue pump replacement I’m worried about now 😂
Old Jun 19, 2020 | 02:29 PM
  #505
Mrjay622's Avatar
Don't know how great of a position I'm in ,this car Sat for 3,4 years before I rescued it..
fuel was like varnish injectors plugged up ,just a mess... everytime I turn around something else is getting replaced. Ugh! Hasn't been on the road since I started this post. Don't even know if it's worth it yet...
Old Jun 19, 2020 | 02:34 PM
  #506
Mrjay622's Avatar
All I have for tea is a Lipton tea bag I found in the kitchen behind the stove when I bought this place... Looks ok to me...
Old Jun 19, 2020 | 02:36 PM
  #507
dangelous's Avatar
I’ll bring my own then just in case! And you’ll have that it up and running in no time, I’ve no doubt
Old Jun 19, 2020 | 03:03 PM
  #508
Mrjay622's Avatar
It's warming up , I want to check the transmission fluid level one last time before I drop it..
Old Jun 19, 2020 | 05:41 PM
  #509
dangelous's Avatar
Looks great!! Still didn’t know where to use my trolley jack on it! Couldn’t use the standard jack points as the jack got in the way of the axle stands! So had to use the jaguar jack!
Old Jun 19, 2020 | 05:47 PM
  #510
Highhorse's Avatar
MJ has quite an investment in floor jacks I see. I think he's keeping Harbor Freight in business by himself...lol
Old Jun 20, 2020 | 06:18 AM
  #511
Mrjay622's Avatar
lol. YOUR SO MEAN!
1st poor mint sauce now my 45$ jacks....
smh.
Old Jun 20, 2020 | 07:03 AM
  #512
dangelous's Avatar
Fuel pump changed, bit fiddly but not bad, hope everything is all correct, I’ve a clip left over and no idea where the hell it came from, any ideas? Can’t imagine it’s off the fuel
Old Jun 20, 2020 | 07:34 AM
  #513
Mrjay622's Avatar
That's good news. ..
Sorry No Idea where that came from...
Never having the pleasure of replacing a fuel pump on a jag...... go back and few post CK put up a diagram of the fuel tank and pump parts... maybe that may help?
Keep up the good work...
Old Jun 20, 2020 | 07:38 AM
  #514
Mrjay622's Avatar
I don't see it here... maybe # 3
Old Jun 20, 2020 | 09:43 AM
  #515
dangelous's Avatar
Potentially, I’m sure I’ll find out eventually!! Appreciate the diagram!
Old Jun 20, 2020 | 09:50 AM
  #516
Mrjay622's Avatar
Let's hope you find out before you put all back together. And it's not something that belongs in the tank....
Good luck. .. Keep moving forward. ..
Old Jun 20, 2020 | 10:04 AM
  #517
dangelous's Avatar
That was my fear but all there is is one pipe which definitely had a clip on! I’m sure I’ll find it!!
Old Jun 21, 2020 | 06:34 AM
  #518
Highhorse's Avatar
...or its off of something totally unrelated and you just happened to find it doing this and you knock your brain out just to realize that.
Old Jun 21, 2020 | 06:42 AM
  #519
dangelous's Avatar
Unlikely as I put all the bits In one place, filter going back on later so we’ll what happens 🙏🏻
Old Jun 21, 2020 | 08:37 AM
  #520
Highhorse's Avatar
That's a smart thing, have you reviewed any differences in the old pump vs the new one? Say maybe what was previously a 2 piece slip clip on a joint, is now a pressed piece single assembly?
I reviewed this as best I could to no answer (its an XK8, but the setup is the same). Perhaps you can see something dangelous? In either case if any of you were interested why the fuel lines are such a PITA, there are some excellent camera shots showing why... JagRepair.com - Jaguar Repair Information Resource
