1999 XJ8 code P0358 won't start
Old Dec 26, 2016 | 02:40 AM
TonyXJ8's Avatar
Default 1999 XJ8 code P0358 won't start
Hi all,
My beautiful Xj8 Sport wont start.
Battery is charged and has the right voltage when testing with a voltmeter.
Have tested the starter, flywheel is spinning freely.
Would a failed coil cause the ECU to cut voltage to all coils ???
Your help is appreciated (in advance).
Tony
Old Dec 26, 2016 | 04:08 AM
Welcome to the forum Tony,
I've copied this question from Intro to X308 forum. Members here with the same model will be able to help.
Old Dec 26, 2016 | 05:57 AM
RJ237's Avatar
Spinning freely suggest you may have bore wash. Did you shut the engine off after running briefly, as in just moving the car over? Another possibility is fuel pump failure. Also see below:
https://www.jaguarforums.com/forum/g...d-first-30792/
Old Dec 26, 2016 | 08:53 AM
JagV8's Avatar
P0358 is coil for cyl #8 and no the PCM won't cut all the fuel so suspect bore wash (and move coil to another cyl or replace).
Old Dec 26, 2016 | 09:20 PM
TonyXJ8's Avatar
Hi,
I did quickly move the car across my parking area (only took less than a minute). Sounds like it could be borewash. Will try the solution for that.
My previous loves
1977 XJ6
1985 XJS
My future loves
2001 XKR
Last edited by TonyXJ8; Dec 27, 2016 at 02:32 AM. Reason: More info about my car likes (and previous ownership).
Old Jan 1, 2017 | 12:07 AM
TonyXJ8's Avatar
Thumbs up Problem solved
Hi all,
It wasnt borewash.
A faulty relay on fuel pump circuit was the culprit.
Thanks for all your help.
Tony
Old Jan 1, 2017 | 09:50 AM
JagV8's Avatar
Working again... is good! Happy New Year.
hazjag
XJ40 ( XJ81 )
Nov 15, 2016 10:46 PM
twack
Oct 19, 2016 03:59 PM
motorhommie
Oct 19, 2016 02:28 PM
twack
Oct 19, 2016 01:33 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
