200 Cell HP Cats for XJR
Old Aug 12, 2013 | 04:55 PM
Maxville's Avatar
Default 200 Cell HP Cats for XJR
Hello everybody,
i'm planning to build up some HP Cats for my XJR.
The plan is to use 200 cpi metallcats because i dont want to get problems with the lambda sensors and they should fit nearly p&p ( on the exit i want to get 2 1/4 or 2,5" but at the moment i'm not sure if 2,5" is required)
My first step is to measure out how my space i have, to decide which shape i chose and to design the connecting plates.
If you have some additional ideas for me please feel free
Best regards from Munich
Maxi
Old Jun 23, 2014 | 01:07 PM
VIAPA2's Avatar
Originally Posted by Maxville
Hello everybody,
Maxi
I have 200 cell cats on my XJR. Expect it to be a lot louder but not obnoxiously loud. The cats are connected to 2.5in piping to a X-pipe, mid resonator and 2 rear axle mufflers. The two forward mufflers are deleted.
Old Jun 23, 2014 | 02:47 PM
grandell's Avatar
Nameless Performance do 200 cell cats for our cars
https://namelessperformance.com/
They've been covered quite a bit in the XK forum, but a few people have used them on XJ's as well.
Hopefully someone with some actual experience will offer some useful advice about them, as I see they have two versions listed on their website for XK's, but nothing for XJ's
Old Jun 24, 2014 | 09:33 AM
Dan Hiatt's Avatar
I am running the 200 cell Nameless sport cats with an otherwise stock exhaust. Other posts have said an increase of ~10hp with the cats. They deepen the exhaust note, which sounds very good.
Old Jun 24, 2014 | 03:07 PM
grandell's Avatar
Which ones did you use, and which year is your car?
Or when you mentioned you had an XJ, did they know which ones you'd need?
Old Jun 24, 2014 | 05:06 PM
Dan Hiatt's Avatar
Sorry, I have a 2000 XJR. I bought the cats from Waterdragon when, I believe, he couldn't pass emisions testing in California. They are ceramic coated, which is nice. I am adding a 2nd exhaust gasket to the bottom connection because of a bit of leakage. If you do a search for "nameless cats" and "Waterdragon", you should be able to get more details on the cats.
Hope that helps.
Old Jun 25, 2014 | 05:45 AM
XJR-99's Avatar
There are some other sport catalysts available for our cars. Here one XJR installation:
Old Jun 26, 2014 | 07:13 AM
dc4prez's Avatar
Mine is a 99 XJR - quiksilver 2 1/2" system plus nameless 200 cell cats - I bought the cats a few years ago to suit a XKR, (that was all they supplied them for back then) XJR and XKR cats are identical in all respects, I had them fabricate them with 2 1/2" outlets especially -
I have always thought I could have spent that $1,000 more wisely.
I also had alignment troubles using the solid copper flange gaskets they supply, ended up using OEM gaskets
Old Jun 27, 2014 | 12:40 AM
XKRacer's Avatar
I use single cell cats () with no lamda issues..... Emissions is obviously a different matter but works a treat
Aus V8S
Nov 13, 2015 11:01 AM
Safari
Sep 14, 2015 10:29 AM
skadmiri1
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
