2000 xj8 catalytic converters
Old May 19, 2009 | 12:47 AM
still_rubbin1's Avatar
Default 2000 xj8 catalytic converters
heres a kicker for you techs i took my car to the muffler shop cause its throwing a catalist code he was stumped on how to get them off they are directly below the exhaust manifold and on the bottom of the converters its cast with no bolts how do i get these out is the first question......can i hollow them without messing up my car (they arent strict on emissions where im at) ?
Old May 19, 2009 | 01:53 AM
wazari's Avatar
There are bolts that connect the downpipe assembly (catalytics) to the exhaust manifold at the top. There is a mounting bracket attached directly to the downpipe assembly in front which bolts directly to the frame of the car. These bolts must be removed. Assuming you have disconnected the exhaust system from the convertors, disconnected the O2 sensor wiring, and removed all the bolts, the convertors should drop straight down.
You do not want to hollow out the convertors.
Old May 19, 2009 | 04:08 PM
nicknack's Avatar
Just curious, what is the reason behind not wanting to eliminate the converters ie. hollow them out???
Old May 20, 2009 | 01:44 AM
wazari's Avatar
It's called air pollution. Eliminating the catalyitics is against the law and you're creating additional pollutants.
If you're so concerned about performance, run high performance cats like emitech's which flow like crazy.
Old May 20, 2009 | 07:43 AM
nicknack's Avatar
Exceeding the speed limit is also illegal, in addition an increase in pollution. And we don't want to do that now do we....
Old May 20, 2009 | 08:20 AM
wazari's Avatar
Hmmm. you want to compare a traffic citation with a felony, hmmm okay...........
Also if you're car is running correctly, you'll find most cars actually pollute less from 2000 to 3000 RPM vs idle to 1500 RPM.
Old May 20, 2009 | 04:16 PM
sparkenzap's Avatar
And your car will suddenly display the CEL and throw low cat performance codes. Ok for you, but pretty daunting situation if you move to a city or state with EPA testing.
Old May 20, 2009 | 05:41 PM
jag_genius's Avatar
have to bang off the intermediate muffler pipes first.. unless it is an R.
then 8 nuts at the top .. then cat brackets..
Old May 20, 2009 | 07:46 PM
i was just curious i didnt want to go back with factory cats i do know that god knows how much they are thanks for the info i appreciate it ....
Bcrary3
Sep 12, 2021 05:41 AM
Aus V8S
Nov 13, 2015 11:01 AM
corysansburn
Sep 10, 2015 06:15 AM
skadmiri1
Sep 9, 2015 11:27 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
