2000 xj8 error code c1137 .. please help
Old Nov 17, 2014 | 12:16 AM
2000jagxj8's Avatar
Default 2000 xj8 error code c1137 .. please help
I bought a 2000 xj8 .. it has 3 codes the p1000 .. po332 .. and the c1137 code in question.. i have 12volts at the module and the ground tests good.. i am gonna have the module rebuilt but was unsure if that would fix it.. anyone have experience with c1137 and how did you fix it..
Thanks guys any help is awesome
Old Nov 17, 2014 | 06:24 AM
RJ237's Avatar
That's the first C1137 I have seen, and no history of it on the forum. It does indicate an internal fault and may not be repairable. Sending it out for testing is about all you can do.
What device did you use to read this code?
When you have time please visit the new member area and introduce yourself. When you have sent ten messages and been a member for about three days you will be able to download pdf files. But you may be able to download the factory manual JTIS21 from the Sticky on the forum page right now. It has all the codes and repair info.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Nov 17, 2014 | 07:30 PM
2000jagxj8's Avatar
I used an autozone obd checker.. I cant find anything on the c1137 code anywhere .. but am positive that its the abs ecu.. I just don't get it .. I don't want to have to pay 250 plus dollars on a used one.. its 45 bucks on ebay to have them rebuild it .. im assuming they just resolder the 2 points where the power connects.. I need my abs and tcs to work and that's the only code I get for it.. all my wheel sensors check out good when I check them with my meter.. please help me have the courage to waste money on a rebuild.. I really just need one person to tell me exactly how they fixed the c1137 code.. thanks again guys
Old Nov 18, 2014 | 05:43 AM
RJ237's Avatar
What Autozone reader did you use that lists C codes? I wasn't aware of them having one.
Old Nov 18, 2014 | 03:11 PM
thesameguy's Avatar
Most of the half decent codes scanners these days can pull codes from most modules. My $300 Autel certainly does.
Old Nov 20, 2014 | 07:31 PM
2000jagxj8's Avatar
it was the manager of autozone and I believe he used his personal scanner cause I told him I needed the abs codes and he put back one scanner and grabbed a lot bigger one and said that it would read the c codes for me .. I guess no one has ever got this code so im out of luck.. I guess ill just have the module rebuilt and waste my money if it doesn't fix it.. im really disappointed because it seems like this forum is full of useful info but nothing about c1137.. that sucks
Old Nov 21, 2014 | 03:35 AM
Welcome to the forum,
I'm always a little suspicious of B, C or U codes reported by anything other than dealer level diagnostics. Plenty of scanners can read more than P codes but whether they report Jaguar B, C or U codes accurately is another matter.
P1000 : this is NOT a fault code. It is a status setting indicating that all OnBoard monitoring test have not been completed since the last memory clear. You will ALWAYS see either P1000 or P1111 (all tests completed since last memory clear).
P0332 : KS sense circuit out of range (low voltage) on B bank
C1137 : here is the extract from the Jaguar DTC listing:
As you can see, the possible causes are simple and jump direct from circuit fault to module failure.
Old Feb 18, 2022 | 08:36 AM
Pristine97XK8Convertible's Avatar
Default DTC C1137 on '97 XK8
May I know what did you finally do to resolve the DTC C1137 issue because my '97 XK8 has just thrown this code?
Bcrary3
Sep 12, 2021 05:41 AM
tonyforman
Sep 10, 2015 07:23 PM
corysansburn
Sep 10, 2015 06:15 AM
AtholC
Sep 9, 2015 09:07 PM
Super Cat
Sep 9, 2015 03:24 PM
