2001 XJR wont spin over?
Old Feb 23, 2011 | 03:19 PM
AndyUK's Avatar
Default 2001 XJR wont spin over?
It wont spin over, unlocks ok, headlights all bright etc but just wont even try to spin over?
It did have a jump start as its been stood for a bit.
I'm very new to jags and grateful for all help.
Is there a chance I have blown a fuse (what numbers to check would handy) or maybe a relay or is there a master reset facilty ? ? ? ?
Is there anyway I can re program the key? (The remote fob/plip is fine) in case the immobiliser has freaked out?
Got me baffled as it drove fine a few days back?
Never let me down before.
Old Feb 23, 2011 | 03:20 PM
AndyUK's Avatar
Grateful for all help
Old Feb 23, 2011 | 03:51 PM
AndyUK's Avatar
I meant to say drove ok a few days ago, admittedly only a short drive to get it warm as stood for a while.
Old Feb 24, 2011 | 06:44 AM
Sean B's Avatar
Andy can you hear the intercooler pump when you turn the ignition on?
Does it make any attempt, like a click sound?
Have you fitted a fresh fully charged battery?
I'd check the connections to and around the fuse boxes on the passenger side under the bonnet. Undo, clean with a bit of sandpaper and bolt back up, they get covered in oxide over time. You could have bust a fuse, but lets check the simple stuff first.
Old Feb 24, 2011 | 09:58 AM
H20boy's Avatar
It requires a lot of power to start, I can have radio, headlights, gauge lights, everything...and it still won't turn over if the voltage isn't there.
Also, try to move to Neutral and give it a shot, then back to Park if that doesn't work. Though not totally common, a neutral safety switch can require either adjustment or replacement, as the P and N selection isn't consistent (electronics) and you can only fire the starter in either of the two positions.
Old Feb 24, 2011 | 12:55 PM
AndyUK's Avatar
Thanks for your replies
Now the key wont turn!!!
Tried wiggling the key, wiggling the wheel, bypassed the shift catch to select neutral but key wont turn!
Old Feb 27, 2011 | 08:37 PM
MidlifeXJR's Avatar
Can't help you on the key not turning... but I have had the car not turn over and it might be a bad connection at the main fuse block in the trunk. If you check where the positive cable runs to from the battery, that might be where the source of the problem lies. Gus has something on his site about this if I'm not mistaken.
Old Feb 27, 2011 | 09:39 PM
Gus's Avatar
Gus
If your key will not turn on take the steering wheel and wiggle it as you turn the key. It may take a little force to wiggle the steering wheel in both directions as you turn the key. As Matt had suggested try starting the car in “N” you will need to apply the brake to move the shifter to “N” from “P” and give it a try. If that is not working you need to check the high Power Protection Module located in the trunk of the car near the battery. If you are going to be checking it I would Highly suggest that you disconnect the battery and at that time check the battery terminals. See if this gets you going.
Attached Thumbnails 2001 XJR wont spin over?-highpowerprotectionmodule.jpg   2001 XJR wont spin over?-97powerdist.jpg   2001 XJR wont spin over?-starter-aj27-n-.jpg
2001 White XJ8
Feb 25, 2021 05:02 PM
picard
Oct 12, 2015 11:56 AM
GGabriel
Sep 18, 2015 08:44 PM
ym37tech
Sep 18, 2015 12:25 AM
tonyforman
Sep 10, 2015 07:23 PM
