98 VDP Cooling System
Old Jun 12, 2014 | 07:16 PM
TheHilds's Avatar
Default 98 VDP Cooling System
Does anyone know what would cause coolant to leak from in front of the front driver side wheel after putting the car in park and shutting the engine off?
Old Jun 12, 2014 | 07:51 PM
Rlover's Avatar
Are you sure it's coolant? Your AC evaporate drains in that location. Ifs it's stock OEM coolants its orange and not it would be green
Old Jun 12, 2014 | 09:00 PM
TheHilds's Avatar
Yes I am sure as the low coolant light comes on and I keep filling the tank up 2 time a day and it is a redish orange color.
Old Jun 12, 2014 | 09:11 PM
sparkenzap's Avatar
That is where the overflow tank is located. I suspect it is cracked
OR
Your tubes connecting to the expansion tank are swapped and the engine is blowing coolant into the overflow tank.
Old Jun 13, 2014 | 01:09 PM
TheHilds's Avatar
Thank you for the diagram. The lines were swapped. Problem fixed and the diagram also helped me order new hoses and lines that I was having a hard time purchasing.
Old Jun 13, 2014 | 02:14 PM
JimmyL's Avatar
Man, they should color code those coolant hoses/pipes on the coolant reservoir !
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
1100me
Sep 7, 2015 06:26 AM
