99 xj8 blend door locations?
Old May 23, 2013 | 08:35 PM
coastaljag98's Avatar
Default 99 xj8 blend door locations?
I am gettjng heAt and Ac at the same time. Where are the blend doors located so I can see if its stuck ??
Old May 24, 2013 | 05:25 AM
test point's Avatar
There has been posts on insulation coming loose and blocking the door(s). I did a search but was not able to locate it. Seems like I remember that the insulation was 'fished' out.
As far as where the doors are; they are buried deep in the climate control system. Jaguar places them on the assembly line first and builds the car around them.
Old May 24, 2013 | 07:31 AM
Figured. So nobody else has heat coming out at the same time as the Ac???
Old May 24, 2013 | 03:29 PM
Doug Dooren's Avatar
Both the evaporator and heater core are in a box behind the center vents. I believe all air moves through the evaporator - directly into the cabin for cooling or then through the heater core for heat. It sounds like you have a bad blend door motor? I just stripped a totaled 308 for a Mark 2 project - with the dash out the HVAC box is right there, but that is a lot of work. Not sure if you can access any of the motors with just the center console and lower trim panels out. Good luck.
Old May 24, 2013 | 04:17 PM
Sean B's Avatar
Your climate control should be able to tell you, to enter the climate diagnostic
1 Simultaneously hold AUTO and RECIRC, switch ignition on - display element check.
2 Press AUTO - display of stored fault (numeric) code, if zero appears there are no stored codes
3 Press Face - scroll through stored faults ( max 5)
4 Simultaneously press Face and R - clear stored fault codes (may need to be repeated for each fault)
5 Press Recirc (press FAN to skip actuator check) - initiate actuator check (actuator codes 20-27)
6 Press FAN - exit error check mode
I've attached the error codes and notes in the PDF fine.
Hope this helps
Old May 24, 2013 | 05:50 PM
Okay I am getting code 43. Where is this cold air bypass servo motor?? Anyone have diagrams or directions on how to change this part??
Old May 24, 2013 | 06:32 PM
This is the top motor on the left (drivers) side of the box I described above. It sits directly above the upper heater hose. The manual says remove instrument panel (I believe that's the dash) for access and remove motor. The motor is held in with 2 small phillips screws - I'd try everything to get at it to release it from the damper and check its operation. If the motor works the damper may be binding. Good luck.
Old May 24, 2013 | 06:55 PM
anyone have directions for removing the "instrument panel" or dash?? I can get the motor for like 20 bucks lol but I'm sure its hours worth of work to replace a simple thing....ughhhghhgghg and its damn June in Florida!!!
Old May 24, 2013 | 10:02 PM
Wonder if I could disconnect heater??? And not worry about pulling the dash?
Old May 25, 2013 | 06:30 AM
Bump
Old May 25, 2013 | 08:58 AM
test point's Avatar
Pulling the fuse or disconnecting the circulation pump would significantly reduce the hot water. I have installed a cut-off valve in heater hoses in a number of cars but not a Jaguar.
I believe the 'instrument panel' is just that and not that big a deal to remove. There have been discussions on that.
I have found that searching outside of the forum can produce much more information than an internal search giving you 50 threads to read through.
Old May 25, 2013 | 07:44 PM
Unplugged the pump. Still get heat lmao. Dammit!!!
Old May 26, 2013 | 04:06 PM
Sean B's Avatar
Got that here
https://www.jaguarforums.com/forum/x...65/#post564595
Take your time and you'll get at it, lower and move the wheel out all the way for space, or remove the wheel if it's a struggle. They're made to work on, not like the modern Jag's, that is indeed whole dash out.
The next step is to confirm if it's jammed or dead. Either way once into it, you can sort the heat.
Hope this helps.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
TexasCat
Sep 8, 2015 04:36 AM
