99 xj8 lighting problems
Old Feb 3, 2009 | 01:03 PM
crownman56's Avatar
Default 99 xj8 lighting problems
First let me say thanks for the great help and info that gets posted here. so here is my problem. first off my license plate light has never worked, replaced bulb several times with no luck have checked all fuse boxes with no luck any suggestions? also the lights in the climate control and clock have same problem cannot find any blown fuses these lights did work when car was first purchased. any help would be appreciated.
Old Feb 3, 2009 | 01:19 PM
JagtechOhio's Avatar
Greetings,
Lisence plate lamps have lost porew or ground due to a broken wire at the right side boot lid hinge, beneath the plastic cover. Test for power and ground at the lamps, and go to the hinge if you're lacking. The wiring insulation may not be broken, but the wire strands inside are. A number of trunk release, trunk light and lisence plate light failures all come from damage to this haarness as a result of the wires being repeatedly flexed.
Dash bulbs are bad dash bulbs. Individual replacement is possible but not always convenient.
Old Feb 3, 2009 | 07:12 PM
Brutal's Avatar
Originally Posted by jagtechohio
greetings,
lisence plate lamps have lost porew or ground due to a broken wire at the right side boot lid hinge, beneath the plastic cover. Test for power and ground at the lamps, and go to the hinge if you're lacking. The wiring insulation may not be broken, but the wire strands inside are. A number of trunk release, trunk light and lisence plate light failures all come from damage to this haarness as a result of the wires being repeatedly flexed.
eeeewwww another right on the money internet diag....good job andy
Old Feb 3, 2009 | 10:22 PM
Thanks BRUTE,
It was pretty funny the first time I came across this. I was opening and closing the trunk and watching the trunk light come on whenever it felt like it: I swore there was a faulty switch at the hinge, like on all the previous models. Probably spent an hour looking for something that wasn't there.
Old Feb 4, 2009 | 06:37 AM
Cerberus's Avatar
Sort of on-topic, do one of you techs have info for removing the HVAC unit? One of the backlight bulbs just went out and I'd like to replace it. How do I get the unit out the quickest and easiest way?
Old Feb 8, 2009 | 10:21 AM
orca99usa's Avatar
So what is the fix for this? Do you buy a wiring harness in one piece or just splice the existing wires? My trunk lights haven't worked since I bought the car, and I suspect that this is what is wrong.
Old Feb 8, 2009 | 10:39 AM
jag_genius's Avatar
just to repair the harness..
Cerberus- have to put in nuetral then lift the shifter surround gentily upward... once off remove 2 7mm bolts and 2 nuts.. then remove the sport switch surround then push the metal bracket forwared that has the studs for the nuts you just removed then carefully remove wood ski slop.. up then out.. place a rag over the shifter illumination.. then undo 3 screws to take the radio out.. once out turn the climate control over undo 2 small screws and the rear cover comes off .. then find the bulb thats out and turn to remove..
Old Feb 11, 2009 | 01:22 PM
crownman56's Avatar
just a note to add i pulled the climate control and clock out of the dash to check on replacing bulbs and they appear to be sealed i was worried about splitting them to get at bulbs any thoughts? thanks again
Old Feb 11, 2009 | 04:10 PM
Cerberus's Avatar
Oh brother that's ridiculous. Who knows when I'll find time for that project....
I wouldn't be worried as long as you find the right places...
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
